Certificate not trusted
Questions on desktop sync clients only
Postby Jeroen » Thu Jul 05, 2012 10:05 pm
I have a small problem.
When I install and configure the sync program on my own pc it works correctly.
But when I get on a different computer, go to the website (ssl) and then install the Sync Client and set it to use SSL, it gives an Error that the Root CA is Self Signed.
The CA I use is trusted on all pc's (AddTrust CA) I know of and it is strange when we install the sync client and force it to use SSL that it gives an error that it is not trusted, while a minute ago it was good on Firefox.
Why does it not see the Certificate Authority as trusted while it is a PositiveSSL Certificate?
-Jeroen
User avatar
Jeroen
Re: Certificate not trusted
Postby hefeweiz3n » Fri Jul 06, 2012 7:53 am
Did you install the CA systemwide or just in Firefox?
hefeweiz3n
Postby Jeroen » Fri Jul 06, 2012 11:14 am
hefeweiz3n wrote:Did you install the CA systemwide or just in Firefox?
Well the CA worked on all systems I have been before and on every browser, it is a little strange that ownCloud does not recognize it but ALL the browsers do..
User avatar
Jeroen
Return to OwnCloud desktop sync clients
Users browsing this forum: fhmanas and 1 guest
