Windows Client Cannot Connect To owncloud Server
Questions on desktop sync clients only.
You want to report a bug or check for feature requests?
Please visit https://github.com/owncloud/mirall/issues
Postby dhimans » Fri Aug 10, 2012 2:19 pm
I am new to owncloud. I am facing a major problem. I installed owncloud on my website and its working but the windows client cannot connect. Its giving the following errors
Trying to connect to ownCloud at http://dhimans.in/owncloud/owncloud/...
Failed to connect to ownCloud!
Error: Socket operation timed out An ownCloud connection could not be established.
Please check again.
Can anyone help me please.
Regards,
Dhiman
dhimans
Re: Windows Client Cannot Connect To owncloud Server
Postby mccar75287 » Fri Aug 10, 2012 5:00 pm
If your not using port 80 or 443 then you need to specify the external port in the link like so:
http://dhimans.in:83/owncloud/owncloud/
and then nat that internally to port 80 or 443 as required.
mccar75287
Postby jeremykeithhammond » Mon Jul 29, 2013 8:28 pm
I am having the same issue. I am unsure how to check which port I'm using, but as I assume those are defaults, I have done nothing to change it. How might I check which port I'm using to troubleshoot?
jeremykeithhammond
ownCloud version: 5.0.9
Webserver: Apache
OS: Unknown
Return to ownCloud desktop sync clients
Users browsing this forum: Yahoo [Bot] and 3 guests
