Failed Update to 6.0.0a
Postby svenbaer » Tue Dec 24, 2013 3:35 pm
Hi community,
I get an error, when I will install the new ownCloud Version with the Updater in the Webinterface.
After the download and the backup the system will try to copy the files and then the system throws an error.
Thanks for your help and Merry Christmas,
svenbaer
svenbaer
Beginner
ownCloud version: 6.0.0
Webserver: Apache
Re: Failed Update to 6.0.0a
Postby srfreeman » Tue Dec 24, 2013 3:43 pm
When all else fails... Refer to the documentation: http://doc.owncloud.org/server/6.0/admi ... ml#upgrade
srfreeman
OwnCloud professional
ownCloud version: 6.0.4
Webserver: Apache
PHP version: 5.3.10
Postby svenbaer » Tue Dec 24, 2013 3:59 pm
Thanks for your answer, but it doesn´t work - I think, I must do the Update manuell or waiting for the next release...
svenbaer
Beginner
Webserver: Apache
Postby RealRancor » Tue Dec 24, 2013 4:07 pm
when having such problems please please post more infos.
"I'm getting an error" and "doesn't work" are clearly not enough informations to get any help.
*inactive*
RealRancor
OwnCloud master
Postby svenbaer » Tue Dec 24, 2013 4:23 pm
I know, but the Updater doesn´t say more words...
Here it´s a picture.
svenbaer
Beginner
Webserver: Apache
Postby RealRancor » Tue Dec 24, 2013 4:32 pm
ah i see. The data/owncloud.log could give you some hints on the error which happens during the upgrade.
*inactive*
RealRancor
OwnCloud master
Postby svenbaer » Fri Dec 27, 2013 12:15 pm
ok. I look in this log file and check the errors. If i have no idea to solve this, i send you the log.
svenbaer
Beginner
Webserver: Apache
Postby njotha » Thu Jan 02, 2014 2:48 pm
I had the same Problem -- blank Screen when trying to upgrade from 5.0.14 to 6.0.0a on a QNAP TS 259 Pro+.
It worked after setting
eeaccelerator.enable = 0
in the php.ini.
And even after successfull upgrade, OC 6.0.0a works only with eeaccelerator = 0, setting it back to 1 leads to a "page not found" or to a blank screen. So it very much seems like an OC bug handling the php accelerator.
Oh, sorry - all the best to all of you for 2014!!!
njotha
ownCloud version: 6.0.0a
Webserver: Apache
OS: Linux Embedded
PHP version: 5.3.26
Postby McOc » Thu Jan 02, 2014 6:33 pm
njotha wrote:eeaccelerator.enable = 0
in the php.ini.
I am glad I retried it!
This was also my issue.
(Additionally I needed to restart the webserver. But this was kinda solvable. ;) )
Working with QNAP 469-Pro
McOc
Starter
ownCloud version: 7.0.3
Webserver: Apache
Return to ownCloud Community Edition 6.x
Users browsing this forum: Yahoo [Bot] and 12 guests
