OSX LDAP Integration
Postby wsmiley » Thu Feb 23, 2012 11:26 pm
Having trouble getting owncloud to authenticate with a ldap user. When we setup we can see the users in ldap but no login
Host has ip address
Port 389
Name and password blank
Base dc=machinename,dc=domain,dc=ca
Filter %uid
Display fields Name uid
We can authenticate with a local user as well
Just installed mamp and owncloud 3 this morning
Running on Lion Server
wsmiley
Re: OSX LDAP Integration
Postby q3media » Thu Mar 08, 2012 9:12 am
Have you tried setting the filter to 'uid=%uid'?
In my case that works.
And probably you should set 'Display Name Field' to cn.
That looks nicer.
q3media
Postby nigeowncloud » Tue Jun 19, 2012 1:51 pm
wsmiley
I am also wishing to add own cloud to my companies lion server.
Did you manage to install and run mamp successfully on the server,
Do you know if its possible to install owncloud without mamp, just using the lion server settings.
Nige
nigeowncloud
Postby obinett » Thu Jun 21, 2012 8:55 am
nigeowncloud wrote:wsmiley
Nige
Hi!
I have installed owncloud on OSX server 10.5.8 and it works fine with LDAP. The issue just now is the connection with MySQL. Why using MAMP? You have an excellent platform within OSX server.
Just install it in on OSX and enjoy!
User login filter: uid=%uid << Don't miss.... on OSX
User list filter: objectClass=person <<< Don't miss....
Of course you must use Host: 127.0.0.1 if you have set up LDAP correctly..
Good luck!
obinett
Users browsing this forum: Bing [Bot], Google [Bot] and 21 guests
