WebDav on version 3
WebDav on version 3
Postby redsumo » Fri Feb 24, 2012 3:57 pm
HI Guys,
I have installed own cloud version 3 and it works a treat I can use webdav with firefox but I can't seem to get it working on my mac I have tried finder and cyberduck but it just won't work.
Im not sure if i have missed anything but any help would be welcome!
Cheers
Rich
redsumo
Re: WebDav on version 3
Postby ademcan » Fri Feb 24, 2012 4:02 pm
Hi redsumo,
I am using Mac Os X Lion and the following address to access my oc webdav file list:
press Apple+K or "Go" menu and "Connect to Server"
http://SERVER/files/webdav.php
SERVER= the path to your owncloud instance.
Try this way to see if it works.
ademcan
Beginner
Postby redsumo » Fri Feb 24, 2012 4:08 pm
This is what im trying and I get
Check the server name or IP address, and then try again. If you continue to have problems, contact your system administrator.
My apache log shows:
86.135.229.193 - richard [24/Feb/2012:10:13:08 -0500] "GET /files/webdav.php HTTP/1.1" 200 1846 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:10.0.2) Gecko/20100101 Firefox/10.0.2"
86.135.229.193 - - [24/Feb/2012:10:14:40 -0500] "OPTIONS /files/webdav.php HTTP/1.1" 401 - "-" "WebDAVLib/1.3"
86.135.229.193 - matt [24/Feb/2012:10:14:41 -0500] "OPTIONS /files/webdav.php HTTP/1.1" 200 - "-" "WebDAVLib/1.3"
86.135.229.193 - - [24/Feb/2012:10:14:41 -0500] "OPTIONS /files/webdav.php/ HTTP/1.1" 401 - "-" "WebDAVFS/1.9.0 (01908000) Darwin/11.3.0 (x86_64)"
86.135.229.193 - matt [24/Feb/2012:10:14:41 -0500] "OPTIONS /files/webdav.php/ HTTP/1.1" 200 - "-" "WebDAVFS/1.9.0 (01908000) Darwin/11.3.0 (x86_64)"
86.135.229.193 - matt [24/Feb/2012:10:14:41 -0500] "PROPFIND /files/webdav.php/ HTTP/1.1" 500 - "-" "WebDAVFS/1.9.0 (01908000) Darwin/11.3.0 (x86_64)"
Cheers
Richard
redsumo
Postby ademcan » Fri Feb 24, 2012 4:16 pm
Hi Richard,
On your server address do you also add /owncloud/
I have the same error message if I try
instead of
http://SERVER/owncloud/files/webdav.php
Just in case.
ademcan
Beginner
Postby redsumo » Mon Feb 27, 2012 3:03 pm
No I have uploaded the files to the root not /owncloud/
Cheers
Richard
redsumo
Postby redsumo » Tue Feb 28, 2012 2:31 pm
I have resolved this by moving to Ubuntu server for some reason my centos install wouldnt play ball with webdav!
Cheers
Richard
redsumo
Postby magnetoza » Fri Mar 02, 2012 9:22 pm
make sure you have the following installed also.
libproxy libproxy-bin libproxy-python pakchois
you should be able to yum and apt-get them to install.
once that done restart apache. mac and window should now be able
connect fine to the webdav. if still have issue's with windows
have a look here http://owncloud.org/support/webdav/
magnetoza
Users browsing this forum: Bing [Bot] and 17 guests
