[FIXED] [Developer Version] Keeps scanning files
Postby Zakoon » Wed Apr 25, 2012 12:19 pm
Hi Dev-Version users,
on the current developers version (April, 25th) from https://gitorious.org/owncloud , the file-App just keeps scanning for files and refreshing the page. It's not usable anymore.
Anyone else with this problem?
Any idea how to fix this?
Cheers, Zak.
Zakoon
Starter
Re: [Developer Version] Keeps scanning files
Postby lgwapnitsky » Wed Apr 25, 2012 8:46 pm
getting it here as well...
lgwapnitsky
Postby Zakoon » Thu Apr 26, 2012 3:16 pm
It's fixed, now. :-)
Zakoon
Starter
Re: [FIXED] [Developer Version] Keeps scanning files
Postby roeschu » Sat May 19, 2012 6:11 pm
i installed 5 pre alpha, and it works not.
Here the log:
[19-May-2012 17:15:05 UTC] PHP Fatal error: Uncaught exception 'PDOException' with message 'SQLSTATE[HY000]: General error: 1366 Incorrect string value: '\xD6sterr...' for column 'name' at row 1' in cloud\lib\db.php:598
Stack trace:
#0 cloud\lib\db.php(598): PDOStatement->execute(Array)
#1 cloud\lib\filecache.php(120): PDOStatementWrapper->execute(Array)
#2 cloud\lib\filecache.php(579): OC_FileCache::put('/app_developmen...', Array, '')
#3 cloud\lib\filecache.php(539): OC_FileCache::scanFile('/app_developmen...', '')
#4 \cloud\lib\filecache.php(537): OC_FileCache::scan('/app_developmen...', Object(OC_EventSource), 159, '')
#5 \cloud\apps\files\ajax\scan.php(18): OC_FileCache::scan('', Object(OC_EventSource))
#6 \cloud\lib\base.php(304): require_once('E:\wwwroot\swis...')
#7 \cloud\index.php(65): OC::loadfile( in E:\wwwroot\XXXXXXXXcloud\lib\db.php on line 598
How to fix it?
Regards
Roger
roeschu
Beginner
Postby Legoless » Sat Jun 09, 2012 2:41 am
I have this problem too, running Windows Server 2008 R2, latest IIS and PHP 5.4.
If anyone has managed to solve it, let me know. ;)
Thanks.
Edit: The problem is in ProcessQuery function in file lib/db.php. Check the replacing functions for your database. :)
Legoless
Beginner
Postby krispy » Wed Jul 11, 2012 4:26 pm
Ok everyone keeps saying they fixed this issue can you please take the time to post the steps on how you fixed this issue.
krispy
Postby hellsy » Wed Jul 11, 2012 4:35 pm
I had a similar problem with one of my users having to rescan constantly. I tried many browsers and found that one of the files caused this issue. What i did was, let the scan work with IE 9, and I noticed after a while that, it got stuck with one file. I moved that file to a directory not scanned by OC and let the scanning process start again. I had to repeat this process 4-5 times. Then it was able to finish the scanning process. I am not saying this is the solution; but it definitely worked for me..
hellsy
Starter
Users browsing this forum: Bing [Bot] and 4 guests
