SSL Connection Popup
Postby rendered » Tue May 22, 2012 10:17 am
I'm using OC v4 Server and 1.0.2 sync client running on Windows x64 and using Apache and MySQL. I've configured OC to use SSL but I seem to get a pop up everytime I want to access the status or add a folder in the sync client.
The popup is a SSL Connection popup mentioning "Warnings about current SSL Connection:" then a blank page and then at the bottom it has a checked box and: "check if you want t continue via SSL and trust the shown certificates.". I click OK and it pops up about 4 times and then goes away - then it might sync my data if I'm lucky.
Is anyone else having a similar issue or knows how to solve this?
rendered
Re: SSL issue - warnings about current ssl connection
Postby mac.loud » Sat Jun 23, 2012 2:29 pm
I'm having the same issue; 4x same empty warning screen. I connect using an IP address i.s.o. a DDNS. I used the IP address as Common Name in the certificate.
I read some posts where people actually had issues with their certificate but they forgot to use there fully qualified hostname as Common Name in the certificate. Instead, I used my IP address for that.
greetz
update
oC = 4.0.3
oC Client = 1.0.3
mac.loud
Re: SSL Connection Popup
Postby rendered » Thu Jul 19, 2012 1:30 pm
I've just updated to the latest server and client build and I'm still getting this issue. I get the following screen everytime owncloud wants to sync/connect to my server:
I have also recreated my certificates and checked the common name in the cert. Please help.
rendered
Users browsing this forum: Google [Bot] and 20 guests
