Hello everybody,
Environment: OpenSUSE 11
Server: VMWare-Server
Database: MySQL 5.1
OC-Version: 4.0.2
PHP-Version: 5.3.5
i've installed owncloud 4.0.2 on opensuse and everything works great - even the ldap->active directory connection. if i login via ldap and upload files, i can share it it with groups, but not with users.
Everytime i try to share with a user, i get a error message like this "You can't share with User XY". In the admin-panel i get the message "Error - files_sharing - Unexpected Error : You can't share with User XY".
I've tried to find a workaround, but no solution works for me.
Can anybody help me? Is there a config failure caused by me or is there a bug in the file_sharing
app?
Thank you very much!
