oc System requirements
Version 4 is not supported anymore! Please upgrade your ownCloud for security and support.
Postby braindoc » Thu Jul 19, 2012 5:19 pm
I wanted to know about the system requirements of owncloud. everything I could find was about the software requirements (PHP, Mysql).
But what kind of Hardware requirements need the Server? (CPU, RAM)
And, if one uses the virtual machine image of the oc Server?
Thank you, briandoc
braindoc
Re: oc System requirements
Postby braindoc » Thu Oct 25, 2012 3:49 pm
huh, nobody has got an idea about the requirements?!
braindoc
Postby RandolphCarter » Thu Oct 25, 2012 5:18 pm
I think that vastly depends on the number of users you want to support and the amount of data you want to provide access to over owncloud.
I have it running on a Atom machine with 2 gig RAM, and it's working decently. Not too fast, but acceptable most of the time.
RandolphCarter
Inventory
ownCloud version: 7.0.2
Webserver: Apache
PHP version: 5.5.x
Postby braindoc » Thu Oct 25, 2012 6:34 pm
thanks for sharing your experiance, Randolph.
Your're right, of course it depends on the number of users and the tasks.
I was more thinking of a minimum requirement. For example how much Ram do I need to run owncloud without problems (and I#m not talking about no concurrent users or big files).
But Atom and 2GB ram is a number. Is there anybody running owncloud on a slower system?
braindoc
Postby braindoc » Thu Oct 25, 2012 6:52 pm
huh, just found somebody using a setup with 512 meg RAM & arm5@800Mhz
http://forum.owncloud.org/viewtopic.php?f=3&t=3751&p=8419&hilit=limited#p8419
I guess that might be close to the minimum :shock:
braindoc
Postby RandolphCarter » Thu Oct 25, 2012 9:00 pm
The memory_limit in .htaccess is set to 512MB, so I guess less than 512MB is suboptimal. I have tried running it with 24MB memory_limit, for a short time, though, and it worked flawlessly. During that period, there was however no file scanning or other memory intensive operation running...
RandolphCarter
Inventory
Webserver: Apache
PHP version: 5.5.x
Users browsing this forum: No registered users and 25 guests
