Error 'MYSQL_ATTR_INIT_COMMAND'
Postby ahevans » Thu Aug 02, 2012 9:58 pm
Hi, this is my setup
Owncloud 4.0.6
WHM 11.32.3
Cent OS 5.8
Apache 2.2.22
Php 5.3.15
MySQL 5.1.63
IE 9
I have a VPS with WHM and CPanel
I have edited the php.ini in usr/local/lib/ and added
extension=pdo_mysql.so
at the end
Restarted Apache numerous times, reuploaded installed files
At install I get the error:
Fatal error: Undefined class constant 'MYSQL_ATTR_INIT_COMMAND' in /home/****/public_html/****
/lib/db.php on line 123
Completley baffled, please help!
ahevans
Re: Error 'MYSQL_ATTR_INIT_COMMAND'
Postby FordPrefect » Thu Aug 02, 2012 10:09 pm
isn't there a
Code: Select all
extension=php_mysql.so
extension=php_mysqli.so
needed? Really I am not sure, but vaguely remember something like this.
FordPrefect
Helpful Elf
Postby ahevans » Sat Aug 04, 2012 4:31 pm
Those are related to mysql and the error is related to a php feature, really stuck, please someone help before I bin owncloud and have to think about another solution
ahevans
Postby FordPrefect » Sat Aug 04, 2012 10:44 pm
Well, to me it sounded mySQL related ... hope you can solve the problem!
FordPrefect
Helpful Elf
Postby ahevans » Sun Aug 05, 2012 9:55 am
Infact, you were right, the PHP build on the server didnt have PDO MySQL enabled
ahevans
Postby FordPrefect » Sun Aug 05, 2012 6:04 pm
Cool ... so this works now for you?
FordPrefect
Helpful Elf
Users browsing this forum: No registered users and 23 guests
