I haven't been able to find a clear answer, other than basic discussions...
I am trying to reinstall/reconfigure a OC4.5 instance to use MySQL
I am not concerned about users -- we can set those up again...
I can't seem to get the setup wizard to recognize MySQL as an option
When I change the Install=>"false" and open the browser, the setup screen appears -- however, when I click advanced it says "SQLite will be used" and never gives me the option to use MySQL
I have also changed the config.php to reflect MySql with no luck
I even deleted the config.php and modified the sample config to reflect MySQL and it still continues to say SQLite will be used...
Am I doing something wrong or missing something to enable the MySQL option? Oh, and yes, MySQL is installed
Ubuntu is the OS
Thanks!
Mike
