I just updated owncloud 4.5.2 to 4.5.3 on my server. Everything works fine (in some cases even better than before), but then I noticed the following warning in the admin section:
"Your data directory and your files are probably accessible from the internet. The .htaccess file that ownCloud provides is not working. We strongly suggest that you configure your webserver in a way that the data directory is no longer accessible or you move the data directory outside the webserver document root."
This is weird because I had nothing changed in /data, just updated, and there was no warning before. Even more strange: the .htaccess file in /data still is from the date when I installed 4.5.2 ...
I had a look into the forum and found that same bug as something in 5.0 alpha from May/jun 2012 ... ist this a zombie.bug??
Is there a solution? or maybe a .htaccess file that I could install instead??
Thanks for your help!
Jay
