3rd party apps not installing
Postby LinuxLove » Fri Dec 14, 2012 9:16 pm
I cannot get 3rd party apps installed. Keep getting "Error while enabling app". So, I chowned it to nobody:nobody (apps dir) too, but that didn't solve it.
chown -R nobody:nobody apps
drwxrwxrwx 31 nobody nobody 4.0K Oct 24 11:29 apps/
This is the entire output of the log, not understanding it much. Every 3rd party app gave me the same error actually
root@server [/home/user/public_html/owncloud/data]# cat owncloud.log
{"app":"contacts","message":"OC_Contacts_Addressbook::OC_Contacts_Addressbook::setActive, id: 1, active: 1","level":3,"time":1351119558}
{"app":"core","message":"Archives of type application\/octet-stream are not supported","level":3,"time":1351119912}
{"app":"core","message":"Archives of type application\/octet-stream are not supported","level":3,"time":1351119928}
{"app":"core","message":"Archives of type application\/octet-stream are not supported","level":3,"time":1351119948}
{"app":"core","message":"Archives of type application\/octet-stream are not supported","level":3,"time":1351120027}
{"app":"core","message":"Archives of type application\/octet-stream are not supported","level":3,"time":1351120090}
{"app":"core","message":"Archives of type application\/octet-stream are not supported","level":3,"time":1351120103}
{"app":"core","message":"Archives of type application\/octet-stream are not supported","level":3,"time":1351120120}
{"app":"contacts","message":"OC_Contacts_Addressbook::OC_Contacts_Addressbook::setActive, id: 2, active: 1","level":3,"time":1351120809}
Ran tool.php, all good. Not running Windows either, nor changed default theme.
I am not running php safe mode nor suPHP at this time.
I tailed apache logs and domain logs together while attempting to install the 3rd party apps, nothing shows up in logs odd enough during the error message. The only thing that shows up in logs while tailing it is a 200 message, so not even an error
"POST /owncloud/settings/ajax/enableapp.php HTTP/1.1" 200 62 "http://www.domain.com/owncloud/settings/apps.php?installed" "Mozilla/5.0 (Windows NT 6.2; WOW64; rv:17.0) Gecko/20100101 Firefox/17.0"
PHP 5.3.19 (cli) (built: Dec 3 2012 11:16:00)
Copyright (c) 1997-2012 The PHP Group
Zend Engine v2.3.0, Copyright (c) 1998-2012 Zend Technologies
with the ionCube PHP Loader v4.2.2, Copyright (c) 2002-2012, by ionCube Ltd., and
with Zend Guard Loader v3.3, Copyright (c) 1998-2010, by Zend Technologies
Code: Select all
drwxr-xr-x 14 nobody    65534 4.0K Nov 21 18:47 ./
drwxr-x--- 18 user nobody 4.0K Dec 10 23:51 ../
drwxr-xr-x 25 nobody    65534 4.0K Nov 14 02:32 3rdparty/
drwxrwxrwx 31 nobody    65534 4.0K Nov 14 02:32 apps/
-rw-r--r--  1 nobody    65534  585 Nov 14 02:31 AUTHORS
drwxrwxrwx  2 nobody    65534 4.0K Nov 14 02:32 config/
drwxr-xr-x  9 nobody    65534 4.0K Nov 14 02:32 core/
-rw-r--r--  1 nobody    65534 2.5K Nov 14 02:32 cron.php
drwxrwx---  4 nobody   nobody 4.0K Dec 14 14:11 data/
-rw-r--r--  1 nobody    65534  12K Nov 14 02:32 db_structure.xml
-rw-r--r--  1 nobody   nobody  44K Dec 14 14:10 error_log
drwxr-xr-x  2 nobody    65534 4.0K Nov 14 02:32 files/
-rw-r--r--  1 nobody    65534  939 Nov 14 02:32 .htaccess
-rw-r--r--  1 nobody    65534  853 Nov 14 02:32 index.php
drwxr-xr-x 64 nobody    65534 4.0K Nov 14 02:32 l10n/
drwxr-xr-x 18 nobody    65534 4.0K Nov 14 02:32 lib/
drwxr-xr-x  2 nobody    65534 4.0K Nov 14 02:32 ocs/
-rw-r--r--  1 nobody    65534  443 Nov 14 02:32 public.php
-rw-r--r--  1 nobody    65534  960 Nov 14 02:32 remote.php
drwxr-xr-x  6 nobody    65534 4.0K Nov 14 02:32 search/
drwxr-xr-x  8 nobody    65534 4.0K Nov 21 18:43 settings/
-rw-r--r--  1 nobody    65534 1.2K Nov 14 02:32 status.php
drwxr-xr-x  2 nobody    65534 4.0K Nov 14 02:31 themes/
[PHP Modules]
bcmath
calendar
Core
ctype
curl
date
dom
ereg
exif
filter
ftp
gd
hash
iconv
imap
ionCube Loader
json
libxml
mbstring
mcrypt
mysql
mysqli
openssl
pcre
PDO
pdo_mysql
pdo_sqlite
posix
Reflection
session
SimpleXML
sockets
SPL
SQLite
sqlite3
standard
timezonedb
tokenizer
XCache
xml
xmlreader
xmlwriter
Zend Guard Loader
zip
zlib
[Zend Modules]
Zend Guard Loader
This is a cPanel / CloudLinux box.
LinuxLove
Beginner
Re: 3rd party apps not installing
Postby RandolphCarter » Sat Dec 15, 2012 12:23 am
Have you checked this thread already? Seems to be related to me.
RandolphCarter
Inventory
OwnCloud version: 5.0.5
Webserver: Apache
PHP version: 5.4.13
Postby LinuxLove » Sat Dec 15, 2012 2:44 am
Saw it, not related to my issue.
Using default theme
Running Linux (CloudLinux)
PHP 5.3.9 as pasted earlier
Not running suPHP nor safe php
LinuxLove
Beginner
Users browsing this forum: clayton256 and 15 guests
