CSync [1.2.0 Win] failed to find a specific file
You found a bug or you're missing a major feature? Just ask and discuss
We use this forum to discuss about bugs and feature requests. If you are sure you found a bug or have a good feature request: Don't hesitate and use our github issue tracker at https://github.com/owncloud/core/issues
Postby blanch » Fri Feb 08, 2013 2:57 pm
My oc cliwent has stopped syncing at a specific point
The client has issued the following error message:
Csync: failed to find a specific file
Digging in the log file of the client, I have found that this error happens at the very first time that the opendir procedure is called
Next there are a few log lines close to the error
02-08 12:24:24:702 oc_module: opendir method called on ownclouds://owncloud.clinic.cat/ownclou ... bdav/Dades Xarxa/Concurs POCs UCIs
02-08 12:24:26:482 oc_module: Request failed, don't take session header.
02-08 12:24:26:483 oc_module: Neon error code was 1
02-08 12:24:26:483 oc_module: WRN: propfind named failed with 1, request error: 500 Internal Server Error
02-08 12:24:26:483 oc_module: Errno set to 5
Any idea of what is causing this error ?
blanch
ownCloud version: 4.5.4
Re: CSync [1.2.0 Win] failed to find a specific file
Postby RealRancor » Fri Feb 08, 2013 3:12 pm
Probably not a bug. Most time an internal server error means there is something wrong with the configuration on your server so please have a look at your webservers error log and the error log of php like described here:
viewtopic.php?f=17&t=7330
*inactive*
RealRancor
OwnCloud master
Return to Discuss possible bugs & feature requests
