Lost Password
Version 5 is not supported anymore! Only security issues are fixed. Please upgrade your ownCloud.
Lost Password
Postby woodlawn » Wed Mar 27, 2013 7:17 pm
I have owncloud set up with the same E-mail settings I had with 4.5.x and Lost password does not work with version 5. I get a blank screen with the URL http://www.XXXXX.com/owncloud/index.php/lostpassword/. The screen just goes white.
Checking the error log I see this entry:
[27-Mar-2013 17:03:52 UTC] PHP Fatal error: Call to undefined method OC_Mail::ValidateAddress() in /XXX/XXX/public_html/owncloud/lib/public/util.php on line 222
Any help would be appreciated, I am stuck.
woodlawn
Beginner
Re: Lost Password
Postby RealRancor » Wed Mar 27, 2013 7:23 pm
which PHP version are you running?
*inactive*
RealRancor
OwnCloud master
Re: Lost Password
Postby woodlawn » Wed Mar 27, 2013 7:29 pm
I just checked, 5.1.17, I need 5.3.x right, and I added AddHandler application/x-httpd-php53 .php in my htaccess file, but that did not change anything.
woodlawn
Beginner
Re: Lost Password
Postby woodlawn » Wed Mar 27, 2013 7:34 pm
I just upgraded to 5.3.x and no luck, thoughts?
woodlawn
Beginner
Re: Lost Password
Postby RealRancor » Wed Mar 27, 2013 7:45 pm
Which one of 5.3.x? You need at last 5.3.4
*inactive*
RealRancor
OwnCloud master
Re: Lost Password
Postby woodlawn » Wed Mar 27, 2013 7:47 pm
5.3.22. I see that I can move to 5.4, will ownCloud work with that?
woodlawn
Beginner
Re: Lost Password
Postby woodlawn » Wed Mar 27, 2013 10:50 pm
Upgraded to 5.4.x and same thing is happening.
woodlawn
Beginner
Re: Lost Password
Postby RandolphCarter » Thu Mar 28, 2013 12:01 am
Hm, it doesn't seem to be a general bug, at least for me the lost password reset function works in owncloud 5.
You are sure your ownCloud now runs at least under php 5.3.4? And that all ownCloud files are correctly uploaded to your server?
RandolphCarter
Inventory
ownCloud version: 7.0.2
Webserver: Apache
PHP version: 5.5.x
Re: Lost Password
Postby woodlawn » Thu Mar 28, 2013 12:37 am
Hi
I have upgraded to php 5.4. and am getting a bit further along. Now I get an error at least on the webpage.
I ran the web setup version, and was a clean install.
In the log I now get this:
{"app":"core","message":"Adding user backend instance of OC_User_Database.","level":0,"time":1364423698}
{"app":"mail","message":"Could not instantiate mail function.","level":3,"time":1364423699}
{"app":"core","message":"Adding user backend instance of OC_User_Database.","level":0,"time":1364423699}
woodlawn
Beginner
Re: Lost Password
Postby RandolphCarter » Thu Mar 28, 2013 2:18 am
Could you also check the server log (see this FAQ entry) for any related errors?
Do you have safe_mode enabled by any chance?
RandolphCarter
Inventory
Webserver: Apache
PHP version: 5.5.x
Next
Return to ownCloud Community Edition 5.x
Users browsing this forum: No registered users and 19 guests
