Is this a bug? Installer on IIS7 redirect loop on index.php
You found a bug or you're missing a major feature? Just ask and discuss
We use this forum to discuss about bugs and feature requests. If you are sure you found a bug or have a good feature request: Don't hesitate and use our github issue tracker at https://github.com/owncloud/core/issues
Postby Raybot » Tue Apr 17, 2012 1:57 am
Hi all!
I just installed Owncloud 3.0.2 on a Windows 7 box, following the instructions on http://owncloud.org/support/setup-and-i ... ws-server/ . Everything went fine up until I tried to open http://localhost/owncloud/ (which should load index.php) - at that point I get the "The page isn't redirecting properly" error from Firefox. It appeared that index.php kept redirecting to itself.
I got as far as the following statement in lib/base.php:
Code: Select all
      if (!OC_Config::getValue('installed', false) && OC::$SUBURI != '/index.php') {
         $url = 'http://'.$_SERVER['SERVER_NAME'].OC::$WEBROOT.'/index.php';
         header("Location: $url");
         exit();
Now my PHP is very rusty so I haven't been able to figure out exactly what is wrong with this (or what is wrong with my setup that is causing this to not realise it's already executing index.php) but if I comment this block out (or otherwise stop the IF statement from executing) everything works, I can install and it's now all working.
Before I file a bug report though I just wanted to run it past here and see if anyone else is having this problem (or has any thoughts on this).
Raybot
Re: Is this a bug? Installer on IIS7 redirect loop on index.
Postby jayuk20 » Tue Apr 17, 2012 10:30 am
How do I comment out or stop if statement, I don't know about php
jayuk20
Postby tofuSCHNITZEL » Thu Apr 26, 2012 11:29 pm
Same problem here. also with IIS and also with wamp server. I did not try to comment something out as this should not happen out of the box! Problem persists also with dev. version.
tofuSCHNITZEL
Postby zbrown » Fri Apr 27, 2012 2:58 am
Same problem here - would love the solution if anyone has any ideas.
zbrown
Postby Raybot » Fri Apr 27, 2012 3:47 am
If by "solution" you mean something that'll make it work, as I mentioned in the first post you just comment that block out.
If by "solution" you mean figure out why that block of code isn't doing what the writer intended, well, I guess that'd involve a little more than what I can offer. ;-)
Raybot
Postby zbrown » Fri Apr 27, 2012 4:33 am
Found another report that suggested replacing "false" with "true" in that code and it worked for me. Why this doesn't work right out of the box, I do not know - I get the feeling I'm not done with the problems yet.
zbrown
Postby blanik » Fri Jun 08, 2012 11:40 am
Same problem with 4.0.1 on windows box with xampp. Changed to true as suggested on another thread.
Now need to upgrade PHP from 5.2.5 to carry on testing.
blanik
Postby drhirn » Sat Jun 09, 2012 11:34 am
Problem with the endless redirects is described here: http://forum.owncloud.org/viewtopic.php?f=3&t=2370
It's because of the slash. Windows needs a backslash.
So change
Code: Select all
to
Code: Select all
if (!OC_Config::getValue('installed', false) && OC::$SUBURI != DIRECTORY.SEPARATOR.'index.php') {
This is working with Linux and Windows
drhirn
Starter
Return to Discuss possible bugs & feature requests
