Cannot create user in owncloud 4.0.4
You found a bug or you're missing a major feature? Just ask and discuss
We use this forum to discuss about bugs and feature requests. If you are sure you found a bug or have a good feature request: Don't hesitate and use our github issue tracker at https://github.com/owncloud/core/issues
Postby grasch » Fri Jun 29, 2012 7:46 pm
just moved this issue from the community forum:
I've done a clean install of owncloud 4.0.4 on CentOs 6.2, all is running fine,
but I cann't create any user; the system is just doing nothing...
I've activated debugging, but there's no error entry in any of the logfiles (webserver,
owncloud-log).
OS: CentOs 6.2 64Bit
MySQL: 5.1.61-1.el6_2.1
Apache: 2.2.15-15.el6.centos.1
PHP: 5.3.3-3.el6_2.8
It seems that different people have the same problem.
Günther
grasch
Re: Cannot create user in owncloud 4.0.4
Postby Tany » Sun Jul 01, 2012 9:43 pm
Same for me.
No information and no error message...you're not alone buddy! :lol:
Tany
Postby navigium » Mon Jul 02, 2012 8:09 am
I have the same problem with the current development version from git. My workaround:
Add a user to the MySQL database manually. You don't need to add groups or a password. Just do a
INSERT INTO oc_users VALUES ("NewUserName", 0);
and then go to the Users panel in OwnCloud and edit the new user (i.e. set the password and add the account to groups).
navigium
Postby Oski » Mon Jul 02, 2012 9:47 am
The same here.
But i become an error after istallation too.
Code: Select all
Warning: mysql_close(): 29 is not a valid MySQL-Link resource in /kunden/XXXXXX/webseiten/XXXXXX/owncloud/lib/setup.php on line 145
Warning: session_regenerate_id() [function.session-regenerate-id]: Cannot regenerate session id - headers already sent in /kunden/XXXYXXX/webseiten/XXXXXX/owncloud/lib/user.php on line 203
Warning: Cannot modify header information - headers already sent by (output started at /kunden/XXXXXXXX/webseiten/XXXXXXXX/owncloud/lib/setup.php:145) in /kunden/XXXXXXX/webseiten/XXXXXXX/owncloud/lib/setup.php on line 26
I don´t know if this issue comes from this error, but i post it though.
Oski
Postby Zer0 » Mon Jul 02, 2012 5:39 pm
hello,
i have same problem with 4.0.4 !!!!
can you fix this issue ?
thanks
Zer0
Postby Jeroen » Tue Jul 03, 2012 3:32 am
I am having the same problem, and the biggest problem is, I have almost everything the same, even the OS!
User avatar
Jeroen
Postby dmonium » Tue Jul 03, 2012 5:17 am
I have the same trouble.
Please If somebody Knows how to fix, tell us,
Thanks so much
dmonium
Postby Kushulain » Tue Jul 03, 2012 8:06 am
I had the same issue, was trying to crate an account with a 7 digits password and nothing was happening, not even an error message. I tried to create the same account (same login) with a longer password and it worked. It is perhaps a security policy, if so, dev may add a message like "password too short".
Kushulain
Postby Yoh » Tue Jul 03, 2012 12:14 pm
Someone could try to delete in settings/js/users.js line 216 :
<code>
location.reload();
</code>
Delete web browser cache too before testing.
thx
Yoh
Postby Jeroen » Tue Jul 03, 2012 12:49 pm
Kushulain wrote:I had the same issue, was trying to crate an account with a 7 digits password and nothing was happening, not even an error message. I tried to create the same account (same login) with a longer password and it worked. It is perhaps a security policy, if so, dev may add a message like "password too short".
Nope, did not work.
I have actually tried the password Testdurrrrr on a test account but it did not work.
How I can add users is by logging in to my MySQL database and insert the new account name, then I can change passwords, groups, quota and etcetera in the Admin User Panel.
User avatar
Jeroen
Next
Return to Discuss possible bugs & feature requests
Users browsing this forum: No registered users and 6 guests
