"E: Unable to locate package owncloud-client" Ubuntu
rdpbinns
ownCloud version: 4.5.1a
OS: Unknown
PHP version: 5.3
Postby rdpbinns » Sun Sep 08, 2013 11:18 am
Hi, I'm having trouble installing the owncloud-client for ubuntu 12.04.
I follow the instructions here http://software.opensuse.org/download/p ... oud-client
The relevant package is mentioned in the file owncloud-client.list my sources.list.d directory;
I've also tried installing the package with Synaptic. Any help greatly appreciated.
mlo-user
Re: "E: Unable to locate package owncloud-client" Ubuntu
Postby mlo-user » Sun Sep 08, 2013 11:53 am
What happen if you use the command:
apt-get install owncloud-client
BR Marcus
rdpbinns
OS: Unknown
PHP version: 5.3
Postby rdpbinns » Sun Sep 08, 2013 12:01 pm
That's what I tried. This is the precise wording;
Reading package lists... Done
Building dependency tree
Reading state information... Done
mlo-user
Postby mlo-user » Sun Sep 08, 2013 12:12 pm
I had trouble with the new owncloud client (1.4.0) too.
You can try once agein to use the command apt-get update and then apt-get install owncloud-client
I am afraid, that this doesn't work.
Then you can try to download all *.deb files from the repository (if you use 32-bit Ubuntu):
http://download.opensuse.org/repositori ... 2.04/i386/
After that you use the Ubuntu software manager to install the *.deb (right mouse click on the file).
You should start with the lib*.deb
the second to last should be the ocsync_0.90.0-1_i386.deb and the last one the owncloud-client_1.4.0-1_i386.deb
After that you should start the owncloud client in the GUI.
BR Marcus
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Sun Sep 08, 2013 12:28 pm
Could you report this on the mailing list?
Initially, I had some small problems installing the 1.4 version too (see here: viewtopic.php?f=14&t=15503), but it was promised that something would change to resolve that (see here: http://mail.kde.org/pipermail/owncloud/ ... 10481.html). Maybe during trying to fix that issue, something else was broken which is causing the problems you see?
mlo-user
Postby mlo-user » Sun Sep 08, 2013 12:34 pm
@rdpbinns: Does my way work for you?
@RandolphCarter: How can I add the info to the mailing list?
BR Marcus
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sun Sep 08, 2013 2:19 pm
See this overview on how to use the mailinglist:
https://mail.kde.org/mailman/listinfo/owncloud
*gone*
mlo-user
Postby mlo-user » Sun Sep 08, 2013 4:06 pm
@RandolphCarter: done
BR Marcus
rdpbinns
OS: Unknown
PHP version: 5.3
Postby rdpbinns » Sun Sep 08, 2013 10:44 pm
@mlo-user: Yes, that technique seems to have worked - thanks for your help! :)
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Mon Sep 09, 2013 1:26 pm
the repos seems to be broken at the moment (Empty Release and Release.gz files). Its now reported to the bugtracker:
https://github.com/owncloud/mirall/issues/963
*gone*
Users browsing this forum: Yahoo [Bot] and 4 guests
