OC4 Caldav/Webdav doesnt accept username and password
markus
Postby markus » Fri Jun 01, 2012 11:12 am
Environment SharedHosting
Server Apache2
Database mysql
Client Thunderbird+Lightning, IPod Touch 4th
Versions of OwnCloud and PHP ownCloud 4.0.0 + PHP 5.3.1
Hello iam trying so sync the contacts and the calendar. The web-application works fine.
Iam use Thunderbird and Lightning with the newest version.
The calendar names "privat" and the username is for tests "admin".
the url that i´ve tried is : http://[domain].com/remote.php/caldav/calendars/admin/privat but he doenst accept the username and password!? same on ios (ipod touch)
but the login to the frontend works fine..
same procedure with webdav
http://[domain].com/files/webdav.php
he ask me for username and password on and on..
Code: Select all
<d:error><s:exception>Sabre_DAV_Exception_NotAuthenticated</s:exception><s:message>No basic authentication headers were found</s:message><s:sabredav-version>1.6.2</s:sabredav-version></d:error>
i haved read so many threads for owncloud 3 but they hints doesnt work on OC4.
please help?! :)
Ardeo
Re: OC4 Caldav/Webdav doesnt accept username and password
Postby Ardeo » Sat Jun 02, 2012 8:49 pm
just having the same problem.
For me the solution of this post works :).
markus
Postby markus » Mon Jun 04, 2012 12:05 am
thank you verry much.. that works..
ive doubt by myself :D
rkulp208
Beginner
Postby rkulp208 » Mon Jun 04, 2012 11:23 pm
Do you know if this (or its equivalent) works with IIS 7.5?
godfuture
Beginner
ownCloud version: 7.0.3
Webserver: IIS
OS: Windows Desktop
PHP version: 5.5.15
Postby godfuture » Sat May 03, 2014 6:10 pm
Exactly my question!
If someone knows to write the equivalent query of apache auth rewrite for IIS, please tell me:
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
I've tried to import this rule in IIS 7.5 rewrite mod, but the converter tells me that the flag env is not supported.
Does this mean (http://www.micronovae.com/ModRewrite/re ... ility.html, see [E=var:val] Set environment variable) that we cant use basic auth with sabeDav hosted on IIS?
rkulp208
Beginner
Postby rkulp208 » Sat May 03, 2014 9:49 pm
I gave up and put OwnCloud on a Linux server.
