not able to add sync folder
rekorder
ownCloud version: 4.5.0
Postby rekorder » Wed Oct 24, 2012 10:24 am
I'm using ownCloud 4.5 under Ubuntu 12.04 and sync client 1.1.1 under windows xp and mac os x lion.
I'm not able to conncet to a sync folder.
It says "Folder not available, Click to create it." well ,in german actually :-)
Creating doesn't work.
What seems to work, is what is disregarded: using the root directory.
But it fails anyway when it tries to sync.
I wonder if there is a special option for folders I created in owncloud/files?
Do I have to share them.
Must they be owned by a special group.
Behavior is the same and Win and Mac.
Greets,
Edit: looking at my apache2 error.log it says: [error] [client 153.96.69.66] script '/usr/share/owncloud/remote.php' not found or unable to stat
using the web interface seems to work anyway
icedtang
Re: not able to add sync folder
Postby icedtang » Fri Oct 26, 2012 1:51 am
I have exactly the same issue and platform.
I also get these errors in the client sync logs:
10-25 16:44:24:074 ownCloudInfo Network Error: 203
10-25 16:44:24:074 ** webdav mkdir request finished 203
A solution to this problem would be awesome!
rekorder
Postby rekorder » Mon Oct 29, 2012 11:18 am
where did you found the log file?
wasn't able to locate it :(
thebogusman
Postby thebogusman » Mon Nov 19, 2012 11:21 am
This package in ubuntu seems to be broken. Uninstall it and install owncloud manually.
You can use web installer available on the download page, it's very convenient.
