EoL of oC6: Merge oC5 and oC6 forums together
Talk, ideas, changes, critics ... everything Forum related topics
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Sep 29, 2015 11:06 am
oC6 reached End-of-Life this month:
https://github.com/owncloud/core/wiki/M ... e-Schedule
so closing of oC6 forums and merging the topics with the oC5 forums could make sense.
In addition please also note in the text of the locked forums that those are locked because the versions reached End-of-Life
*gone*
AnybodyElse
Developer
Webserver: Apache
Re: EoL of oC6: Merge oC5 and oC6 forums together
Postby AnybodyElse » Tue Sep 29, 2015 2:22 pm
Good idea. I created a new category and moved these unsupported releases into there. That way it is still easily possible to see for what release an issue was filed.
viewforum.php?f=35
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Sep 29, 2015 2:41 pm
Nice, thanks.
I wonder if if would make sense to do the same for the oC 8.0/8.1 forums and the upcoming 8.2/9.0?
*gone*
rakekniven
Inventory
ownCloud version: 9.0.1
Webserver: Apache
OS: Linux Hosting Package
PHP version: 5.6.x
Contact:
Postby rakekniven » Tue Sep 29, 2015 7:42 pm
@RealRancor: Not sure if I got your message.
You like to have new forums for each release like 8.1 / 8.2 / 9.0 ?
ownCloud is not only about files. There is so much more. Explore the apps to extend your ownCloud.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Sep 29, 2015 7:45 pm
Yepp, exactly as issues on oC 8.1 could be completely different as on oC 8.2 because both are major versions. Any opinions about this?
*gone*
rakekniven
Inventory
Webserver: Apache
PHP version: 5.6.x
Contact:
Postby rakekniven » Tue Sep 29, 2015 7:57 pm
No problems with new forums for each release.
Should we have one for 8.1 even if 8.2 is out soon?
rakekniven
Inventory
Webserver: Apache
PHP version: 5.6.x
Contact:
Postby rakekniven » Tue Sep 29, 2015 8:02 pm
Just seen new EOL forum section.
@AnybodyElse: Why did you lock them? People should still be able to ask and discuss questions on older releases. Not everybody can upgrade e.g. php versions on embedded systems.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Sep 30, 2015 10:33 am
rakekniven wrote:Should we have one for 8.1 even if 8.2 is out soon?
I think 8.1 can be skipped as it would need a manual split of topics.
rakekniven wrote:@AnybodyElse: Why did you lock them? People should still be able to ask and discuss questions on older releases. Not everybody can upgrade e.g. php versions on embedded systems.
Personally i think the old versions forums should be locked. We don't have the resources in here to give support for end-of-life and possible buggy versions of oC which already got fixes in newer versions.
Locking the forums will also avoid posts like "i have the same problem" in such older threads where it is often the case that it is absolutely not the same problem.
*gone*
rakekniven
Inventory
Webserver: Apache
PHP version: 5.6.x
Contact:
Postby rakekniven » Wed Sep 30, 2015 3:38 pm
Ok. Got your points.
Other opinions?
btw. Some days ago I already added eol information to red boxes of older forums see viewforum.php?f=26
Return to “Around the forum”
