Forum improvements
Talk, ideas, changes, critics ... everything Forum related topics
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Forum improvements
Postby RealRancor » Tue Jan 26, 2016 10:50 am
maybe for short-therm measures (now that the forums is on phpBB3.1) the following extensions could be enabled:
https://www.phpbb.com/customise/db/exte ... emplate_4/
https://www.phpbb.com/customise/db/exte ... ar_topics/
This could at least help people providing the mandatory infos in their initial post (as nearly no one are reading the support forum rules where this is asked) and show similar topics after they posted their question.
*gone*
AnybodyElse
Developer
Webserver: Apache
Re: Discussion to replace forums
Postby AnybodyElse » Tue Jan 26, 2016 11:41 am
Enabled, see viewtopic.php?f=36&t=32709 for some examples. The issue template should appear soon as well.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Jan 26, 2016 1:16 pm
Great, thanks!!!
Suggestion for the issue template beside the obvious stuff like versions:
- Have you checked the FAQ forums?
*gone*
rakekniven
Inventory
ownCloud version: 9.0.1
Webserver: Apache
OS: Linux Hosting Package
PHP version: 5.6.x
Contact:
Postby rakekniven » Tue Jan 26, 2016 1:33 pm
I will have a look at it later today.
ownCloud is not only about files. There is so much more. Explore the apps to extend your ownCloud.
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Tue Feb 09, 2016 11:10 pm
This module only works for logged in users. Is this on purpose?
rakekniven
Inventory
Webserver: Apache
PHP version: 5.6.x
Contact:
Postby rakekniven » Wed Feb 10, 2016 4:06 pm
tflidd wrote:Is this on purpose?
Looks like. Could not find any setting to change behaviour.
rakekniven
Inventory
Webserver: Apache
PHP version: 5.6.x
Contact:
Postby rakekniven » Wed Feb 10, 2016 5:53 pm
Just found topic regarding anonymous use of similar topics.
https://www.phpbb.com/customise/db/exte ... pic/134461
Do we want to enable similar topics for non-logged in users?
Try to see a bad side (not sure if there is one).
rakekniven
Inventory
Webserver: Apache
PHP version: 5.6.x
Contact:
Postby rakekniven » Fri Feb 12, 2016 8:41 am
Got a response, but not an answer.
See https://www.phpbb.com/customise/db/exte ... 01#p475901
Should I enable it for guests?
tflidd
Forum Moderator
Webserver: Apache
Postby tflidd » Fri Feb 12, 2016 10:13 am
I don't see a reason not to do it. If it helps people solving their issue even without the necessity to register...
rakekniven
Inventory
Webserver: Apache
PHP version: 5.6.x
Contact:
Re: Forum improvements
Postby rakekniven » Fri Feb 12, 2016 10:11 pm
Just enabled similar topics for guests.
btw. splitted topic. We hijacked the previous one IMHO ;)
Return to “Around the forum”
