No apps listed/No internet connection/cURL error 60 message
Here we try to answer typical questions
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Aug 13, 2015 9:16 am
Problem
  • The app page within your installation is just showing the "Not enabled" and "Enabled" categories and not any other like "Productivity".
  • A "No internet connection" message is shown in your admin backend
  • Your logfile is showing a "cURL error 60: SSL certificate problem: unable to get local issuer certificate"
Reasons
  • A broken, outgoing connection to the appstore (https://apps.owncloud.com)
    -> Please check via a call like:
    Code: Select all
    curl -i https://apps.owncloud.com
    if you're able to access the appstore. This call needs to be executed on the command line of your server (via SSH).
  • cURL is using outdated versions of OpenSSL or NSS (oC 8.1.1 should show this in the admin backend)
    -> You need to upgrade those versions to recent ones like stated here.
  • A missing config/ca-bundle.crt (Might be caused by a buggy updater app https://github.com/owncloud/updater/issues/164), for OC 8.1.x you can download it directly from github: https://raw.githubusercontent.com/owncl ... bundle.crt
    This doesn't apply for oC 8.2.x!!!
  • A disabled appstore ('appstoreenabled' => false, in your config.php)
  • A wrong configured appstore URL (Remove 'appstoreurl' => from your config.php)
  • Empty or wrong configured 'proxy' => '', in config.php
  • A broken, outgoing connection to https://www.owncloud.org)
    Code: Select all
    curl -i https://www.owncloud.org
    if you're able to access the page. This call needs to be executed on the command line of your server (via SSH).
Additional info
Feature request to be more verbose on this: https://github.com/owncloud/core/issues/18269
Temporary workaround:
  • Download app from apps.owncloud.com
  • Extract the folder into your apps folder (/path/to/owncloud/apps)
  • App should show up in the list of "not enabled" apps. Enable it.
  • You have some time to fix the problem.
*gone*
User avatar
sksbir
Starter
ownCloud version: 8.0.0
Webserver: Apache
PHP version: 5.5.12
Re: No apps listened / "No internet connection" message
Postby sksbir » Sun Aug 30, 2015 2:47 am
Here a little trick to test A broken, outgoing connection to the appstore (https://apps.owncloud.com)
working test ( ubuntu 15.04 ) :
Code: Select all
root@YYYY:/tmp# wget https://apps.owncloud.com
--2015-08-30 01:56:44--  https://apps.owncloud.com/
Résolution de apps.owncloud.com (apps.owncloud.com)⦠188.138.69.67
Connexion à apps.owncloud.com (apps.owncloud.com)|188.138.69.67|:443⦠connecté.
requête HTTP transmise, en attente de la réponse⦠200 OK
Taille : non indiqué [text/html]
Enregistre : «index.html»
index.html                 [ <=>                         ]  37,68K  --.-KB/s   ds 0,02s
2015-08-30 01:56:44 (1,91 MB/s) - «index.html» enregistré [38585]
root@YYYY:/tmp#
NOT working test : (NAS Asustor AS5002T)
Code: Select all
root@XXXX:/volume1/Web/owncloud/config # wget https://apps.owncloud.com
--2015-08-30 00:55:53--  https://apps.owncloud.com/
Resolving apps.owncloud.com (apps.owncloud.com)... 188.138.69.67
Connecting to apps.owncloud.com (apps.owncloud.com)|188.138.69.67|:443... connected.
ERROR: cannot verify apps.owncloud.com's certificate, issued by '/C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./OU=http://certs.godaddy.com/repository//CN=Go Daddy Secure Certificate Authority - G2':
  Unable to locally verify the issuer's authority.
To connect to apps.owncloud.com insecurely, use `--no-check-certificate'.
I described my problem more in details here
devzero
Beginner
ownCloud version: 8.2.3
Webserver: Apache
PHP version: 5.5.9
Postby devzero » Wed Sep 02, 2015 7:12 am
I had another issue in my config.php, don't ask me who or how that got in, but if you can connect to the app page of oc, but you have still only have enabled and disabled check for that:
Code: Select all
  'apps_paths' =>
  array (
    0 =>
    array (
      'url' => '/apps',
      'writable' => true,
I got it working again as I removed the 0 => between the two array statements:
Code: Select all
  'apps_paths' =>
  array (
    array (
      'url' => '/apps',
      'writable' => true,
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Sep 02, 2015 7:35 am
thanks for posting that info. If you don't have different app folders you can also remove this completely.
devzero wrote:I had another issue in my config.php, don't ask me who or how that got in
Did you copy over the config.sample.php to config.php in the past?
*gone*
pentaxxxer
ownCloud version: 8.1.0
Webserver: Apache
Postby pentaxxxer » Sat Sep 05, 2015 8:42 pm
Please explain in simple steps^ what may i do to fix this:
"A missing config/ca-bundle.crt"
Where may i get this file? Where may i put it?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sat Sep 05, 2015 9:38 pm
The ca-bundle.crt can be downloaded here:
https://github.com/owncloud/core/tree/v8.1.1/config/
or extracted from the owncloud tar.bz2 archive on owncloud.org. The files needs to be put into your config/ folder as already described in the FAQ.
*gone*
optimusprime
ownCloud version: 4.0.8
Webserver: IIS
PHP version: PHP 5
Re: No apps listed/No internet connection/cURL error 60 mess
Postby optimusprime » Fri Oct 16, 2015 2:12 pm
Can the bundle be downloaded somewhere else? I'm having problems accessing that :/
aruji
ownCloud version: 8.1.3
Webserver: nginx
PHP version: 5.6.15
Postby aruji » Sun Nov 08, 2015 3:05 am
I've upgraded my 8.0.8 ownCloud to 8.0.9, then to 8.1.4 and it seems that now I got this problem, but none of the reasons fit my case:
All these happen to me, so I think this is the same problem i have.
    Code: Select all
Tried that and it just returned me the HTML page from apps.owncloud.com. I suppose this means it works.
I'm using an Arch Linux based distributions (arm) and all these packages are already up to date
Curl -V:
Code: Select all
curl 7.45.0 (armv7l-unknown-linux-gnueabihf) libcurl/7.45.0 OpenSSL/1.0.2d zlib/1.2.8 libidn/1.32 libssh2/1.6.0
Protocols: dict file ftp ftps gopher http https imap imaps pop3 pop3s rtsp scp sftp smb smbs smtp smtps telnet tftp
Features: AsynchDNS IDN IPv6 Largefile GSS-API Kerberos SPNEGO NTLM NTLM_WB SSL libz TLS-SRP UnixSockets
I've upgraded manually, so that file came in the package and I confirmed that it is in the correct place.
Confirmed, no 'appstoreenabled' entry on my config at all.
Confirmed, no 'appstoreurl' entry on my config too.
Also confirmed, no such entry on my config.
That works and I've used it to reenable my calendar app, but would like to fix this definitively...
Thanks for any tip :D
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sun Nov 08, 2015 4:25 am
If all those points in here doesn't fit have a look at:
https://github.com/owncloud/core/issues/20028
and watch that issue.
*gone*
seiferflo
ownCloud version: 7.0.3
Webserver: Apache
PHP version: 5.5
Postby seiferflo » Thu Dec 17, 2015 4:28 pm
RealRancor wrote:Problem
Just to thank you because this file saved my problem of no internet connection message thus no possibility to update from 8.1.1
After putting the file, everything worked fine. Thanks a lot.
Return to “FAQ”
