How to find webserver or OC logfile / enable php logfile
Here we try to answer typical questions
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Dec 28, 2012 9:36 am
Most times it's very useful to have a look at the webserver logfile, the own logfile of ownCloud or the logfile of php. On linux you can find (depending on your used distro) at this locations:
ownCloud
/path/to/owncloud/data/owncloud.log
IMPORTANT NOTE:
Please set DEBUG to true (for 8.1 and below):
https://github.com/owncloud/core/blob/v ... .php#L3-L5
or debug => true (for oC 8.2+):
https://github.com/owncloud/core/blob/v ... 1160-L1166
and the loglevel to 0:
https://github.com/owncloud/core/blob/v ... #L153-L154
in your config.php (just add the two directives above) to get more logging output.
Apache
/var/log/apache2/error.log
/var/log/apache2/access.log
NginX
/var/log/nginx/error.log
/var/log/nginx/access.log
lighttpd
/var/log/lighttpd/error.log
/var/log/lighttpd/access.log
PHP
Source of this info: http://davidwinter.me/articles/2009/07/ ... r-logging/
The plain PHP installations shows error instead of logging them. To enable the error log of php you have to edit your php.ini (e.g. /etc/php5/apache2/php.ini) and set these options:
display_errors = off
log_errors = on
error_log = /var/log/php-errors.log
Additional you have to create this logfile with the proper permissions:
sudo touch /var/log/php-errors.log
sudo chown www-data:www-data /var/log/php-errors.log
After this edits you have to restart your webserver and/or your php fcgi process.
*gone*
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Re: Find webserver logfile / enable php logfile
Postby RandolphCarter » Mon Jan 07, 2013 1:01 pm
What I found so far for IIS:
Don't have much experience with IIS, though. If anybody got other or additional information, please share!
User avatar
chassetheater
Helpful Elf
ownCloud version: 8.0.2
Webserver: Apache
PHP version: 5.3
Contact:
Re: How to find webserver logfile / enable php logfile
Postby chassetheater » Fri Mar 01, 2013 10:29 am
RandolphCarter wrote:What I found so far for IIS:
The PHP logfile can also be handy on a Windows environment. You can find this at %SystemDrive%\Windows\temp\php-errors.log. This is the standard location, but you can change this in the php.ini file. Search for error_log (line 922).
You can use the PHP error log instruction from the first post. The permissions have to be configured differently, but that is not too difficult.
red13
ownCloud version: 4.0.7
Webserver: Apache
OS: Windows Desktop
PHP version: 5
Postby red13 » Tue Jun 04, 2013 8:50 am
I have looked for php-errors.log in %SystemDrive%\Windows\temp as you suggested but it's not there.
Could it be in another folder or perhaps I have to create it manually?
__________________________________________________________________________________________
Cloud: centralize your information and access it from anywhere in the world on any computer. Free hosting
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Jun 04, 2013 8:54 am
you have to enable it in your php.ini like described above to get this logfile. If you have already enabled the logging of php the php-errors.log is only created when there is anything to log in in.
*gone*
Sarah3481
Postby Sarah3481 » Sat Apr 12, 2014 11:37 am
Rancor wrote:Hi,
Thanks a million Rancor i was pulling my hair out with the exact same problem but now i finally have it sorted at last! :D
Thanks again,
cpnm.uskondosyokai.comjohnsonvalleyrallyx.comcocktailbarka.comxreccorp.comaccredited-tpi.comelectricallifecyclesolutions.comaberdeenseals.co.ukniwebsports.comzendogcafe.comanimeanarchy.netkittelsonforcongress.comhydragroupltd.com
Sarah
maplewang
Re: How to find webserver or OC logfile / enable php logfile
Postby maplewang » Sun Nov 16, 2014 5:54 am
In version 7 I have this log problem, it
touch(): Unable to create file owncloud.log because Permission denied at /var/www/owncloud/lib/private/log/owncloud.php#49
I set my Data at /var/Data, so the defaulLogFile is /var/data/owncloud.log
I hva set its ownership, but still give errors.
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Sun Nov 16, 2014 11:36 am
Can you post
Code: Select all
ls -la /var/data
? Please note that /var/Data is different from /var/data.
User avatar
RandolphCarter
ownCloud master
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Wed Apr 01, 2015 1:45 pm
Is this the first entry in your logfile? Then this is a known problem, see here: https://github.com/owncloud/core/issues/12893, and isn't critical at all.
Otherwise please tell us where you see it. But in a separate thread, this only marginally has to do with the original topic here.
optimusprime
ownCloud version: 4.0.8
Webserver: IIS
PHP version: PHP 5
Postby optimusprime » Fri Oct 16, 2015 2:14 pm
maplewang wrote:In version 7 I have this log problem, it
I've heard of similar problems, think one of my colleagues had this problem, will ask him.
Return to “FAQ”
