513Mb limit after Install
Please upgrade your ownCloud.
Steve.
ownCloud version: 5.0.3
Postby Steve. » Wed May 08, 2013 6:01 pm
So I installed Owncloud. All seems well until I go to the upload button which shows I have a 513mb limit. My hard drive on this server is 6TB so I know I have well over that to upload.
How can I fix this and why isnt there an option in Admin to adjust max upload settings - I cant see one!
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: 513Mb limit after Install
Postby RealRancor » Wed May 08, 2013 6:12 pm
*gone*
Steve.
Postby Steve. » Wed May 08, 2013 6:25 pm
Thank you for taking the time to reply.
However I dont seem to have the directory:
/lib/filestorage/local.php
So nothing I can edit.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed May 08, 2013 7:27 pm
you don't need to edit anything. This is the relevant part of this FAQ:
The maximum allowed upload size is determined as the minimum of these values:
php configuration entry "post_max_size"
php configuration entry "upload_max_filesize"
The free space left on the target device
Those settings are set in your php.ini or in the .htaccess file in the owncloud root dir.
*gone*
top100
Beginner
PHP version: 5.3
Contact:
Postby top100 » Wed May 08, 2013 7:54 pm
this is the limit only of 1 file. change limitations in php.ini and root .htaccess
grogthegreat
Webserver: Apache
Postby grogthegreat » Wed May 08, 2013 8:28 pm
I had this issue after properly changing the php.ini file. I found out that having AllowOverride set to All in etc/apache2/conf.d/owncloud.conf which seemed to make owncloud ignore the settings in the php.ini file.
Hope this helps!
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed May 08, 2013 8:40 pm
Yes, the AllowOverride must be set to ALL and this is described in the linked FAQ above and in the manuals:
http://doc.owncloud.org/server/5.0/admi ... ing-apache
*gone*
Steve.
Postby Steve. » Thu May 09, 2013 3:48 am
Ahhhhhh.....
The .htaccess file was not visible, so in root ( /var/www/owncloud/) I just issued the command
nano .htaccess
Then edited the relevant lines.
Thanks for all your help you helped me sort my problem. :D
VigAnthony
Webserver: Lighttpd
Database: SQLite
Postby VigAnthony » Fri Feb 20, 2015 2:40 am
The FIle i found that needs editing is the .user.ini file found under /usr/local/www/owncloud (using lighttpd)
kripton
ownCloud version: 8.0.2
Webserver: Lighttpd
PHP version: 5.5.22
Postby kripton » Fri Mar 20, 2015 9:12 pm
VigAnthony, you're my hero! I'm also running lighttpd (with php-fpm) and the file that needs to be changed is the .user.ini-file. Thanks for mentioning this here!
