file sharing via link broken
Please upgrade your ownCloud.
himbeere
Postby himbeere » Thu Mar 14, 2013 1:11 pm
Hello.
After upgrading to 5.0 i'm not able anymore to share via links. I get 404.
"GET /public.php?service=files&t=a27d27681a70bc8f355c54bbff9f93e8&download HTTP/1.1" 404 1365
Some has an idea whats causing this?
Smasher
Webserver: Apache
Database: SQLite
Re: file sharing via link broken
Postby Smasher » Thu Mar 14, 2013 3:37 pm
same problem here. Just installed a fresh copy of version 5.0.
Sharing with a link does not work because the link contained in the email produces a HTTP 404. -> Cloud not found. No difference if using password or not.
regards,
Flo
cantlep
Helpful Elf
ownCloud version: 6.0.3
Webserver: Apache
PHP version: 5.3.3
Postby cantlep » Thu Mar 14, 2013 3:58 pm
Smasher
Webserver: Apache
Database: SQLite
Postby Smasher » Thu Mar 14, 2013 4:13 pm
as far as I can see, owncloud simply doesn't insert a record in the database table "oc_share" for the shared file, resulting in the file not being found when clicking the link in the email.
cantlep
Helpful Elf
Webserver: Apache
PHP version: 5.3.3
Postby cantlep » Thu Mar 14, 2013 4:19 pm
The updated bug tracker link I pasted into my original post contains a fix.
Although having said that, it doesn't seem to work for me for images or single files (only directories) :-(
Smasher
Webserver: Apache
Database: SQLite
Postby Smasher » Thu Mar 14, 2013 4:19 pm
thx seems to be working :)
cantlep
Helpful Elf
Webserver: Apache
PHP version: 5.3.3
Postby cantlep » Thu Mar 14, 2013 4:28 pm
Does it work for you with a single file. i.e When you get the link to a file (not a dir) can you download it? Also, with an image, can you see it in the original page or download it? I can't.... If you can't either, I'll ask the devs to reopen the bug
Smasher
Webserver: Apache
Database: SQLite
Postby Smasher » Thu Mar 14, 2013 4:34 pm
yes, after changig the file lib/files.php according to the post on github it works, even with the preview of the image that I shared.
line 53-55:
change
Code: Select all
if (count($files) == 1) {
         $files = $files[0];
to
Code: Select all
if (is_array($files) && count($files) == 1) {
$files = $files[0];
cantlep
Helpful Elf
Webserver: Apache
PHP version: 5.3.3
Postby cantlep » Thu Mar 14, 2013 4:38 pm
I missed a damn bracket from the is_array...I wish it would have just FATAL'd :lol:
Sorted now!
chillimax
Beginner
Webserver: Apache
PHP version: 5.3.10
Postby chillimax » Thu Mar 14, 2013 6:47 pm
I tired editing the files.php and changing those lines but now instead of a 'cloud not found' I get an error 500 when clicking on the links.
