Upgrade from 5.0.0 to 5.0.1
Please upgrade your ownCloud.
batserra
ownCloud version: 5.0.0
Webserver: Apache
PHP version: 3.4.11
Postby batserra » Tue Apr 02, 2013 12:18 pm
I'm trying to upgrade from 5.0 to 5.1 from web ,i log in with a user with addmin pass, when i do a click in updater button, i recive a message with backup file it's completed ,but ownclod it's still in 5.0 version.
What's wrong? I'm using a Ubuntu 12.10 with latest updates ,My phpmyadmin ,mysql.
And if i download 5.1 full version, and i copy all files in owncloud directory will work?
Thanks for your help
RealRancor
ownCloud master
ownCloud version: 8.2.2
Webserver: nginx
PHP version: 5.6.x
Re: Upgrade from 5.0 to 5.1
Postby RealRancor » Tue Apr 02, 2013 12:21 pm
OC 5.0.1 had a bug with a not updated version string as you can see here:
https://owncloud.org/changelog/
This will be fixed in 5.0.2.
Report a bug? / Request a feature? / Developers contact/feedback? See: https://forum.owncloud.org/viewtopic.php?f=17&t=23696
batserra
Webserver: Apache
PHP version: 3.4.11
Postby batserra » Tue Apr 02, 2013 12:24 pm
Thanks rancor,
So to do an update from 5.0 to 5.2 from web it's correct? or i have to download manually 5.2 files and extract to my owncloud directory?
Thanks again and sorry for my english
RealRancor
ownCloud master
Webserver: nginx
PHP version: 5.6.x
Postby RealRancor » Tue Apr 02, 2013 1:02 pm
Yes, if the update of 5.0.2 is available in your webinterface an update to 5.0.2 should fix this.
batserra
Webserver: Apache
PHP version: 3.4.11
Postby batserra » Tue Apr 02, 2013 1:17 pm
Thanks but now i recive an error, after several minuts ,the page say always that is in maintance mode.
I changed config file to maintenace to false.
After enter again i recive this error:
Turned on maintenance mode
Updated database
SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ownclouddb.oc_fscache' doesn't exist
The update was unsuccessful. Please report this issue to the ownCloud community.
How i can fix it? ,thanks for all your help
RealRancor
ownCloud master
Webserver: nginx
PHP version: 5.6.x
Postby RealRancor » Tue Apr 02, 2013 1:24 pm
Was already reported at the bugtracker:
https://github.com/owncloud/core/issues/2642
Watch this bug for more informations.
batserra
Webserver: Apache
PHP version: 3.4.11
Re: Upgrade from 5.0 to 5.0.1
Postby batserra » Tue Apr 02, 2013 2:40 pm
Thanks i will wait for more information.
Thanks a lot for your help
bertus_f
Webserver: Apache
PHP version: 5.3.20
Postby bertus_f » Tue Apr 02, 2013 4:13 pm
I had the same problem and solved it!
First, create the missing table oc_fscache; copy/paste the code from:
viewtopic.php?f=23&t=9364#p23291
Second, get de server out of maintenance mode:
have a look at your /<owncloud-fileserver-location>/config/config.php and set:
"maintenance" => true,
to:
"maintenance" => false,
Third,try to connect to http://<owncloud-webserver-location>/index.php on your owncloud server again.
In my case it worked! :mrgreen:
RealRancor
ownCloud master
Webserver: nginx
PHP version: 5.6.x
Postby RealRancor » Tue Apr 02, 2013 4:40 pm
Or just use the updated core/ajax/update.php from this pull request:
https://github.com/owncloud/core/pull/2656
hurior
Beginner
Postby hurior » Tue Apr 02, 2013 5:04 pm
bertus_f wrote:I had the same problem and solved it!
to:
Thanks!! It works for me ;)
Users browsing this forum: No registered users and 4 guests
