Sync stopped working after router change
Ask all your questions on mobile clients. Please read the Support Forum Rules
Torqi
Postby Torqi » Sat Dec 05, 2015 5:16 pm
I have changed my network-router to an avm derivate.
Before, I used a Lynksis.
It is not possible to sync my calender now. I am using the CalDav-App on my android device.
(Error 405 PROPFIND)
The only thing that changed is the network address.
From 192.168.1.110 to 192.168.1.23.
The owncloud webserver still works fine. But the sync won't.
When I use the old router again, it works. I can even create new calenders and sync them with no problems.
Do I have to change some IP-Addresses in any config-files? Or does the avm-router blocks some requests.
Thanks!
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Sync stopped working after router change
Postby RealRancor » Sat Dec 05, 2015 5:36 pm
if you get no answer in here i would suggest asking at support forums like:
http://www.router-forum.de/board-avm-fritz-61.html
http://www.ip-phone-forum.de/forumdisplay.php?f=361
As this is not an issue of ownCloud itself you probably find better help in forums dedicated for your router.
*gone*
Return to “ownCloud mobile sync clients”
