Photos are lost after sync on Android (davdroid)
Ask all your questions on mobile clients. Please read the Support Forum Rules
kallecloud
Beginner
ownCloud version: 8.2.1
Webserver: Apache
PHP version: 5.6
Postby kallecloud » Tue Jan 05, 2016 9:22 pm
the following situation seems to occur to a few people: Add a photo to a contact on Android. Sync the contact via davdroid to owncloud. The photo is gone. Doing the same from other clients work fine.
davdroid claims it is an owncloud issue and it is related to vcard 4.0 issues you have in owncloud. See https://forums.bitfire.at/topic/910/pho ... wncloud/13
Is there some other client using vcard 4.0 support that we can test this further? Can someone comment on it?
I am using KDE as another client, does someone know if Kontact on KDE is using vcard 4.0? (no issues here).
Thanks, K.
KekcuHa
ownCloud version: 8.2.2
Webserver: Apache
PHP version: 5.5
Re: Photos are lost after sync on Android (davdroid)
Postby KekcuHa » Fri Jan 15, 2016 11:40 am
There is the patch to fix described issue - https://github.com/gvde/contacts/commit ... 6f4bbb0caa
Hope it will be included in next release.
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Fri Jan 15, 2016 11:51 am
Here you can follow the pull request: https://github.com/owncloud/contacts/pull/1112
(if you test it, you can give feedback if it works in your environment).
Return to “ownCloud mobile sync clients”
