I cannot install a plugin
ownCloud 6.x reached end of life and is officially unsupported. For details see Wiki page.
Please upgrade your ownCloud.
kkaal
ownCloud version: 5.0.12
Webserver: Apache
OS: Windows Server
PHP version: 5.3
Postby kkaal » Wed Dec 04, 2013 7:38 pm
When I try to activate an installed plugin, I get this error message:
Code: Select all
An exception occurred while executing 'INSERT INTO `oc_appconfig` ( `appid`, `configkey`, `configvalue` ) VALUES( ?, ?, ? )': SQLSTATE[23000]: Integrity constraint violation: 1048 Column 'appid' cannot be null
Environment: WAMP
Server: Windows8R2
Database: mySQL
Client: Chrome
OC-Version: 6
PHP-Version: 5.4
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: I cannot install a plugin
Postby RealRancor » Wed Dec 04, 2013 7:58 pm
a short search on google for the error "Column 'appid' cannot be null" leads you to:
http://apps.owncloud.com/content/show.p ... &kbid=2016
where you can find a description and a workaround for this problem which could solve it.
*gone*
kkaal
Webserver: Apache
OS: Windows Server
PHP version: 5.3
Postby kkaal » Wed Dec 04, 2013 8:26 pm
Hi Rancor,
you are right... but what is "Google"?? ;-)
To be totally honest: I did see that post before, but I was not sure that it really was my problem. After your recommendation, I tried it and found that it did not make a difference. It threw the same error.
Question: I am not really sure how to install an App from the UI directly as described in this post. When I enter the page with my installed apps, I would not find the wanted app. Then I go to the website with the repository of the apps and there I only find a download button. I never understood how to "officially" install an app.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Dec 04, 2013 8:36 pm
the apps which are not listed in your apps list needs to be installed manually. For this you need to use the mentioned apps.owncloud.com and hit the download button. Depending how the app developer is providing the app you're getting an link to a download page or a direct download. If you're getting a archive you need to extract it into:
owncloud/apps
After that you need to make sure that the extracted folder matches the name of the <id> value in the apps info.xml like this for example:
https://github.com/owncloud/apps/blob/v ... nfo.xml#L3
*gone*
kkaal
Webserver: Apache
OS: Windows Server
PHP version: 5.3
Postby kkaal » Wed Dec 04, 2013 9:14 pm
Thanks a lot, that helped :-)
Return to “ownCloud Community Edition 6.x”
Users browsing this forum: Bing [Bot] and 2 guests
