[Sucess] ownCloud 6 ldap - fail2ban
ownCloud 6.x reached end of life and is officially unsupported. For details see Wiki page.
Please upgrade your ownCloud.
Grisu1
ownCloud version: 5.0.12
Webserver: Apache
PHP version: 5.4.4
Postby Grisu1 » Fri Dec 13, 2013 2:48 pm
i have updated to from Version 5 to 6.
then i enabled following line in the config.php:
Code: Select all
'log_authfailip' => true,
OK, i see the "Login failed" line in the owncloud.log:
Code: Select all
{"app":"core","message":"Login failed: user 'grisu' , wrong password, IP:19.108.58.43","level":2,"time":"2013-12-13T13:30:07+01:00"}
must now look like the fail2ban filter entry ?
Grisu1
Webserver: Apache
PHP version: 5.4.4
[sucess] ownCloud 6 ldap - fail2ban
Postby Grisu1 » Sat Dec 14, 2013 12:36 am
ok found it. sucessfull
my /etc/fail2ban/filter.d/owncloud.conf
Code: Select all
[Definition]
failregex = {"app":"core","message":"Login failed: user '.*' , wrong password, IP:<HOST>.*
my /etc/fail2ban/jail.conf:
Code: Select all
[owncloud-iptables]
enabled  = true
filter   = owncloud
action   = iptables-multiport[name=ownCloud, port="http,https", protocol=tcp]
           sendmail-whois-lines[name=ownCloud, dest= admin@domain.net, sender= fail2ban@domain.net]
logpath  = /var/www/cloud.domain.net/web/data/owncloud.log
maxretry = 3
jmdekin
Re: [sucess] ownCloud 6 ldap - fail2ban
Postby jmdekin » Wed Jan 08, 2014 6:12 pm
Grisu1 wrote:ok found it. sucessfull
Code: Select all
[Definition]
Code: Select all
[owncloud-iptables]
enabled  = true
filter   = owncloud
maxretry = 3
Thanks for sharing but your code doesnt work.
I get the following error in fail2ban.log
2014-01-08 17:09:05,365 fail2ban.filter : WARNING Unable to find a corresponding IP address for set
When i look at the line:
failregex = {"app":"core","message":"Login failed: user '.*' , wrong password, IP:<HOST>.*[/code]
It misses a } to end the command, can you share where to put that and double check if everything is like it should.
Thanks.
jmdekin
Re: [Sucess] ownCloud 6 ldap - fail2ban
Postby jmdekin » Wed Jan 08, 2014 6:17 pm
Also i get no hits with my regexp, can anyone help me out with this?
Code: Select all
fail2ban-regex /home/johan/owncloud.log /etc/fail2ban/filter.d/owncloud.conf
Running tests
Use regex file : /etc/fail2ban/filter.d/owncloud.conf
Use log file   : /home/johan/owncloud.log
Results
Failregex
|- Regular expressions:
|  [1] {"app":"core","message":"Login failed: user '.*'} , wrong password, IP:<HOST>.*
`- Number of matches:
   [1] 0 match(es)
Ignoreregex
Summary
Sorry, no match
Look at the above section 'Running tests' which could contain important
information.
And my owncloud.log contains this:
Code: Select all
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:31+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:32+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:33+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:34+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:35+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:36+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:37+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:38+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:39+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:40+00:00"}
{"app":"core","message":"Login failed: user 'asdsadasdsad' , wrong password, IP:10.30.203.217","level":2,"time":"2014-01-08T16:19:41+00:00"}
jmdeking
Starter
Postby jmdeking » Thu Jan 09, 2014 12:19 pm
got regex working but fail2ban doesnt ban any IP when hitting it more then 6x with failed login.
Code: Select all
Running tests
Use log file   : /var/www/owncloud/data/owncloud.log
Results
Failregex
|  [1] "app":"core","message":"Login failed: user '.*' , wrong password, IP:<HOST>.*
   [1] 123 match(es)
Ignoreregex
Summary
Addresses found:
[1]
    10.30.203.217 (Wed Jan 08 14:46:57 2014)
    10.30.203.217 (Wed Jan 08 14:46:59 2014)
    10.30.203.217 (Wed Jan 08 14:47:00 2014)
    10.30.203.217 (Wed Jan 08 14:47:01 2014)
    10.30.203.217 (Wed Jan 08 14:47:02 2014)
    10.30.203.217 (Wed Jan 08 14:47:03 2014)
    10.30.203.217 (Wed Jan 08 14:50:43 2014)
    10.30.203.217 (Wed Jan 08 14:50:44 2014)
    10.30.203.217 (Wed Jan 08 14:50:45 2014)
    10.30.203.217 (Wed Jan 08 14:50:46 2014)
    10.30.203.217 (Wed Jan 08 14:50:48 2014)
    10.30.203.217 (Wed Jan 08 14:50:49 2014)
    10.30.203.217 (Wed Jan 08 14:50:50 2014)
    10.30.203.217 (Wed Jan 08 14:50:52 2014)
    10.30.203.217 (Wed Jan 08 14:50:53 2014)
    10.30.203.217 (Wed Jan 08 14:50:54 2014)
    10.30.203.217 (Wed Jan 08 14:50:55 2014)
    10.30.203.217 (Wed Jan 08 14:50:57 2014)
    10.30.203.217 (Wed Jan 08 14:50:58 2014)
    10.30.203.217 (Wed Jan 08 14:50:59 2014)
    10.30.203.217 (Wed Jan 08 14:51:00 2014)
    10.30.203.217 (Wed Jan 08 14:51:03 2014)
    10.30.203.217 (Wed Jan 08 14:51:04 2014)
    10.30.203.217 (Wed Jan 08 14:57:36 2014)
    10.30.203.217 (Wed Jan 08 15:01:57 2014)
    10.30.203.217 (Wed Jan 08 15:01:58 2014)
    10.30.203.217 (Wed Jan 08 15:01:59 2014)
    10.30.203.217 (Wed Jan 08 15:02:00 2014)
    10.30.203.217 (Wed Jan 08 15:02:01 2014)
    10.30.203.217 (Wed Jan 08 15:02:02 2014)
    10.30.203.217 (Wed Jan 08 15:02:03 2014)
    10.30.203.217 (Wed Jan 08 15:02:04 2014)
    10.30.203.217 (Wed Jan 08 15:02:05 2014)
    10.30.203.217 (Wed Jan 08 15:02:06 2014)
    10.30.203.217 (Wed Jan 08 15:02:07 2014)
    10.30.203.217 (Wed Jan 08 15:02:08 2014)
    10.30.203.217 (Wed Jan 08 15:02:09 2014)
    10.30.203.217 (Wed Jan 08 15:02:10 2014)
    10.30.203.217 (Wed Jan 08 15:02:33 2014)
    10.30.203.217 (Wed Jan 08 15:31:17 2014)
    10.30.203.217 (Wed Jan 08 15:31:19 2014)
    10.30.203.217 (Wed Jan 08 15:31:20 2014)
    10.30.203.217 (Wed Jan 08 15:31:21 2014)
    10.30.203.217 (Wed Jan 08 15:31:22 2014)
    10.30.203.217 (Wed Jan 08 15:31:23 2014)
    10.30.203.217 (Wed Jan 08 15:31:24 2014)
    10.30.203.217 (Wed Jan 08 15:31:25 2014)
    10.30.203.217 (Wed Jan 08 15:31:26 2014)
    10.30.203.217 (Wed Jan 08 15:31:27 2014)
    10.30.203.217 (Wed Jan 08 15:31:28 2014)
    10.30.203.217 (Wed Jan 08 15:36:11 2014)
    10.30.203.217 (Wed Jan 08 15:36:14 2014)
    10.30.203.217 (Wed Jan 08 16:15:01 2014)
    10.30.203.217 (Wed Jan 08 16:15:04 2014)
    10.30.203.217 (Wed Jan 08 16:15:05 2014)
    10.30.203.217 (Wed Jan 08 16:15:06 2014)
    10.30.203.217 (Wed Jan 08 16:15:07 2014)
    10.30.203.217 (Wed Jan 08 16:15:08 2014)
    10.30.203.217 (Wed Jan 08 16:15:09 2014)
    10.30.203.217 (Wed Jan 08 16:15:10 2014)
    10.30.203.217 (Wed Jan 08 16:15:11 2014)
    10.30.203.217 (Wed Jan 08 16:15:12 2014)
    10.30.203.217 (Wed Jan 08 16:19:31 2014)
    10.30.203.217 (Wed Jan 08 16:19:32 2014)
    10.30.203.217 (Wed Jan 08 16:19:33 2014)
    10.30.203.217 (Wed Jan 08 16:19:34 2014)
    10.30.203.217 (Wed Jan 08 16:19:35 2014)
    10.30.203.217 (Wed Jan 08 16:19:36 2014)
    10.30.203.217 (Wed Jan 08 16:19:37 2014)
    10.30.203.217 (Wed Jan 08 16:19:38 2014)
    10.30.203.217 (Wed Jan 08 16:19:39 2014)
    10.30.203.217 (Wed Jan 08 16:19:40 2014)
    10.30.203.217 (Wed Jan 08 16:19:41 2014)
    10.30.203.217 (Thu Jan 09 09:13:22 2014)
    10.30.203.217 (Thu Jan 09 09:13:23 2014)
    10.30.203.217 (Thu Jan 09 09:13:24 2014)
    10.30.203.217 (Thu Jan 09 09:13:25 2014)
    10.30.203.217 (Thu Jan 09 09:13:26 2014)
    10.30.203.217 (Thu Jan 09 09:13:27 2014)
    10.30.203.217 (Thu Jan 09 09:13:28 2014)
    10.30.203.217 (Thu Jan 09 09:47:46 2014)
    10.30.203.217 (Thu Jan 09 09:47:47 2014)
    10.30.203.217 (Thu Jan 09 09:48:05 2014)
    10.30.203.217 (Thu Jan 09 09:48:06 2014)
    10.30.203.217 (Thu Jan 09 09:48:07 2014)
    10.30.203.217 (Thu Jan 09 09:48:08 2014)
    10.30.203.217 (Thu Jan 09 09:48:09 2014)
    10.30.203.217 (Thu Jan 09 09:48:10 2014)
    10.30.203.217 (Thu Jan 09 09:48:11 2014)
    10.30.203.217 (Thu Jan 09 09:48:12 2014)
    10.30.203.217 (Thu Jan 09 09:48:13 2014)
    10.30.203.217 (Thu Jan 09 09:48:14 2014)
    10.30.203.217 (Thu Jan 09 09:48:44 2014)
    10.30.203.217 (Thu Jan 09 09:48:45 2014)
    10.30.203.217 (Thu Jan 09 09:48:46 2014)
    10.30.203.217 (Thu Jan 09 09:48:48 2014)
    10.30.203.217 (Thu Jan 09 09:48:49 2014)
    10.30.203.217 (Thu Jan 09 09:48:51 2014)
    10.30.203.217 (Thu Jan 09 09:48:52 2014)
    10.30.203.217 (Thu Jan 09 09:48:53 2014)
    10.30.203.217 (Thu Jan 09 09:48:54 2014)
    10.30.203.217 (Thu Jan 09 09:48:55 2014)
    10.30.203.217 (Thu Jan 09 09:48:56 2014)
    10.30.203.217 (Thu Jan 09 09:48:57 2014)
    10.30.203.217 (Thu Jan 09 09:56:07 2014)
    10.30.203.217 (Thu Jan 09 09:56:08 2014)
    10.30.203.217 (Thu Jan 09 09:56:09 2014)
    10.30.203.217 (Thu Jan 09 09:56:10 2014)
    10.30.203.217 (Thu Jan 09 09:56:11 2014)
    10.30.203.217 (Thu Jan 09 09:56:12 2014)
    10.30.203.217 (Thu Jan 09 09:56:13 2014)
    10.30.203.217 (Thu Jan 09 09:56:14 2014)
    10.30.203.217 (Thu Jan 09 09:56:15 2014)
    10.30.203.217 (Thu Jan 09 09:56:16 2014)
    127.0.0.1 (Thu Jan 09 09:57:22 2014)
Date template hits:
0 hit(s): MONTH Day Hour:Minute:Second
0 hit(s): WEEKDAY MONTH Day Hour:Minute:Second Year
0 hit(s): Year/Month/Day Hour:Minute:Second
0 hit(s): Day/Month/Year Hour:Minute:Second
0 hit(s): Day/MONTH/Year:Hour:Minute:Second
0 hit(s): Month/Day/Year:Hour:Minute:Second
0 hit(s): Year-Month-Day Hour:Minute:Second
0 hit(s): Year.Month.Day Hour:Minute:Second
0 hit(s): Day-MONTH-Year Hour:Minute:Second[.Millisecond]
0 hit(s): Day-Month-Year Hour:Minute:Second
0 hit(s): TAI64N
0 hit(s): Epoch
246 hit(s): ISO 8601
0 hit(s): Hour:Minute:Second
0 hit(s): <Month/Day/Year@Hour:Minute:Second>
Success, the total number of match is 123
However, look at the above section 'Running tests' which could contain important
information.
[/code]
jajo42
ownCloud version: 6.0.0a
Webserver: nginx
Postby jajo42 » Fri Jan 10, 2014 1:07 pm
i have the same problem. fail2ban get the hits but ip will not be blocked.
anyone found a solution for this?
edit:
i found the problem! fail2ban need actual time in the log file but default log time is UTC.
you can set the time zone in the /config/config.php file like this:
Code: Select all
<?php
$CONFIG = array (
/* timezone used while writing to the owncloud logfile (default: UTC) */
  'logtimezone' => 'Europe/Vienna',
jmdeking
Starter
Postby jmdeking » Mon Jan 13, 2014 11:20 am
jajo42 wrote:edit:
Code: Select all
<?php
$CONFIG = array (
Dude, you're the best. I'm gonna test this and get back.
Edit/Update: Works like a charm, thanks a lot for replying your solution in this topic.
User avatar
martinma
Beginner
Webserver: nginx
PHP version: 5.4.4
Postby martinma » Fri Jan 24, 2014 10:56 pm
Implemented and working :-)
Thanks everyone....
JT1301
ownCloud version: 7.0.3
Webserver: Apache
Postby JT1301 » Thu Jan 30, 2014 5:09 pm
Hi there,
is it possible that someone created a howto for this?
I'm not a Linux pro like you all ... :oops:
That would be very helpful.
Thanks!
Regards,
JT
brenard
ownCloud version: 6.0.1
Webserver: Apache
PHP version: 5.4.4
Postby brenard » Fri Feb 07, 2014 11:37 am
I found a solution to make fail2ban work with OwnCloud 6. Fail2ban have some problems to manage date in ISO8601 format (and time zone info), so the easier solution is to put your OwnCloud log in syslog. To do that, you have to put in your config.php file :
Code: Select all
<?php
$CONFIG = array (
'log_type' => 'syslog' ,
With that two parameters, on login failed, you have in /var/log/syslog something like that :
Code: Select all
Feb  4 15:58:52 hostname ownCloud[713]: {core} Login failed: user 'test' , wrong password, IP:AAA.BBB.59.105
So now you can add a corresponding filter in Fail2ban configuration. In /etc/fail2ban/filter.d/owncloud.conf put :
Code: Select all
[Definition]
failregex = .*ownCloud.*Login failed:.*, IP:(?P<host>\S*)
ignoreregex =
And now add a jail for OwnCloud in /etc/fail2ban/jail.conf :
Code: Select all
[owncloud]
enabled = true
port = 80,443
protocol = tcp
filter = owncloud
logpath = /var/log/syslog
And "Voilà" !
Return to “ownCloud Community Edition 6.x”
