Import ics into calendar
ownCloud 6.x reached end of life and is officially unsupported. For details see Wiki page.
Please upgrade your ownCloud.
joeheb
ownCloud version: 5.0.10
Webserver: nginx
Database: SQLite
Postby joeheb » Thu Jan 02, 2014 6:53 pm
maybe I am stupid, but unfortunatley I didn't find any way to import an ics file to my calender. Am I missing something? Thanks
joeheb
joeheb
Webserver: nginx
Database: SQLite
Re: Import ics into calendar
Postby joeheb » Thu Jan 02, 2014 8:10 pm
Grml, ok. Once again I found it out myself ;)
You just have to upload the ics file to your files and then click it in the webgui. OC automatically asks to which calendar it should be imported.
Not_you
Beginner
ownCloud version: 9.0.1
Webserver: nginx
OS: Linux Embedded
PHP version: 5.6.17
Postby Not_you » Sun Jun 01, 2014 2:27 pm
Unfortunately, OC does'nt ask me to import. When I click on the ics-file, I just get normal file operation options, such like delete, rename, etc.
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Sun Jun 01, 2014 3:08 pm
What do you mean exactly, that when you click on the file you get options? Those options should appear already when you hover over the file; and when you click on the line of a file, something specific should happen (download or open for "normal" files, import for ics files, ...).
And sorry if that sounds like a stupid question, just want to make sure we're ruling out the basic possible causes - you do have the calendar app enabled, right ;)?
Not_you
Beginner
Webserver: nginx
OS: Linux Embedded
PHP version: 5.6.17
Postby Not_you » Sun Jun 01, 2014 6:00 pm
Of course :roll:
For months I use per account one personal calendar. I just wanted to import a garbage collection schedule of our town as .ics-file. When I hover the file (after uploading to "files"), my only options are: rename, download, versions, edit and share.
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sun Jun 01, 2014 6:05 pm
there are no options for .ics files. You need to do a double-click on the file to import it.
*gone*
Not_you
Beginner
Webserver: nginx
OS: Linux Embedded
PHP version: 5.6.17
Postby Not_you » Sun Jun 01, 2014 7:18 pm
No luck - by double clicking happens nothing. Ok - my fault, it seems that OC cannot handle this ics-file. I created one with Lighning that works.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sun Jun 01, 2014 10:46 pm
you could have a look at the javascript console of your browser and your logfiles like described here:
viewtopic.php?f=17&t=7330
Maybe there is a problem when parsing such special ics files which could be fixed in ownCloud. Reporting it to the calendar bugtracker could be useful:
https://github.com/owncloud/calendar/issues
*gone*
iainrosen
ownCloud version: 8.0.2
Postby iainrosen » Mon Mar 16, 2015 8:53 pm
OK I got it!
You have to add the file extention .ics manually before uploading or else it will read the file as BIN.
Hope it helps!
User avatar
BuxarNET
Beginner
ownCloud version: 8.2.0
Webserver: Apache
PHP version: 5.3
Contact:
Postby BuxarNET » Mon Sep 28, 2015 12:24 am
I import process endlessly shows.
even after synchronization thunderbird and subsequent export from it, both files were the same, then the process is completed for a long time, but the window was missing.
sorry for my english, I'm Russian
Return to “ownCloud Community Edition 6.x”
Users browsing this forum: Baidu [Spider] and 1 guest
