Disable change password from user backend
ownCloud 6.x reached end of life and is officially unsupported. For details see Wiki page.
Please upgrade your ownCloud.
thorpedo
ownCloud version: 6.0.2
Webserver: Apache
Database: PostgreSQL
PHP version: 5.4
Postby thorpedo » Tue Mar 25, 2014 2:40 pm
We are developing a custom user backend based on user_cas app. We want disable from "personal" page change password action. We saw in some github tickets , template manage which part of this page with implementsActions check. Also we see user_ldap to perform this operation define a own implementsActions method.
We define our implementsActions like user_ldap app but doesn't work. We put some debug lines and see this:
{"app":"cas","message":"implementsActions :256","level":0,"time":"2014-03-25T11:29:48+00:00"}
{"app":"cas","message":"supported actions 69889","level":0,"time":"2014-03-25T11:29:48+00:00"}
Code: Select all
class OC_USER_CAS extends OC_User_Backend {
    public function implementsActions($actions) {
                OC_Log::write('cas','implementsActions :'.$actions, OC_Log::DEBUG);
                return (bool)((OC_USER_BACKEND_CHECK_PASSWORD
                        | OC_USER_BACKEND_GET_HOME
                        | OC_USER_BACKEND_GET_DISPLAYNAME
                        | OC_USER_BACKEND_PROVIDE_AVATAR
                        | OC_USER_BACKEND_COUNT_USERS)
                        & $actions);
How can fix this issue?
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Re: Disable change password from user backend
Postby RandolphCarter » Tue Mar 25, 2014 3:23 pm
Hm, if what you show is all there is in the log, then there doesn't seem to be a check for whether the password can be set or not - because that should be $action = 16, see the xxx_SET_PASSWORD constant defined here: https://github.com/owncloud/core/blob/4 ... nd.php#L35
And whats this "supported actions" log entry about, where does it come from, is it also produced by your app?
thorpedo
Webserver: Apache
PHP version: 5.4
Postby thorpedo » Tue Mar 25, 2014 4:01 pm
@RandolphCarter , i put some OC_Log sentences to try to debug problem, "supported actions" is the output from getSupportedActions.
Code: Select all
OC_Log::write('cas','supported actions '.$this->getSupportedActions(), OC_Log::DEBUG);
What's it's the correct implementation to disable some operations ? Create like user_ldap and a ImplementsActions function? Another way to disable some parts from personal settings?
Thanks for your response
User avatar
RandolphCarter
ownCloud master
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Tue Mar 25, 2014 4:19 pm
Well the getSupportedAction method checks for whether methods exist. So to me it seems one possibility could be just not to have a setPassword function maybe?
About the "correct" way of doing it, you'd have to ask on the mailing list by the way. Here, developers aren't around very often, it's mostly "just" users...
thorpedo
Webserver: Apache
PHP version: 5.4
Postby thorpedo » Tue Mar 25, 2014 4:29 pm
@RandolphCarter thanks , i ask this problem on the maillist .
Thanks a lot!
MU7L3Y
Helpful Elf
ownCloud version: 7.0.2
Webserver: Apache
OS: Linux Hosting Package
PHP version: 5.5.14
Postby MU7L3Y » Wed Mar 26, 2014 12:08 am
I would also like to know how to disable the users ability to change the password. If you find how to do this, please let me know. Thanks
User avatar
RandolphCarter
ownCloud master
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Wed Mar 26, 2014 12:14 am
Are you also referring to that in the context of your own authentication app? Or in general? If in general, I'd recommend to open a separate topic, as this thread is about how to do it when building one's own auth app.
MU7L3Y
Helpful Elf
Webserver: Apache
PHP version: 5.5.14
Postby MU7L3Y » Thu Mar 27, 2014 12:06 am
I see. I was meaning in general..
daniel314
Beginner
ownCloud version: 7.0.3
Webserver: Apache
PHP version: 5.4.16
Postby daniel314 » Mon May 26, 2014 4:00 pm
If someone want to disable "Change Password" from User Backend in General, then you have to comment out the following Line at settings/personal.php:
$tmpl->assign('passwordChangeSupported', OC_User::canUserChangePassword(OC_User::getUser()));
Cheers,
Daniel
MU7L3Y
Helpful Elf
Webserver: Apache
PHP version: 5.5.14
Postby MU7L3Y » Thu May 29, 2014 3:28 am
great, thanks for that Daniel!
Return to “ownCloud Community Edition 6.x”
Users browsing this forum: Baidu [Spider] and 1 guest
