[SOLVED] WebDAV interface seems to be broken
ownCloud 6.x reached end of life and is officially unsupported. For details see Wiki page.
Please upgrade your ownCloud.
kyij1
ownCloud version: 6.0.2
Webserver: Apache
Postby kyij1 » Mon Mar 31, 2014 11:47 am
I have installed owncloud several times before, so this is not the first time for me..
Although during this installation, I get "Your web server is not yet properly setup to allow files synchronization because the WebDAV interface seems to be broken."
--I have tried to reinstall already, but that did not help.
--As I see it is a cert issue, was it caused by following "http://linustechtips.com/main/topic/639 … entry71555"? I believed I have self-signed certificates using the method in the past and never had an issue, although now I am.
When I went to the owncloud installation file, it then gives me another error "Can't create data directory (/mnt/Raidz2/owncloud/)
This can usually be fixed by giving the webserver write access to the root directory."
--This is the directory I am using (and set during install) for the data. When I goto this page, I do not see other error anymore, only when it ran the postcheck.
who/group should own the data folder? And what should I set the chmod to? Before I reinstalled, I was having similar issues, but tried just about every chown/chmod combination I could think of..
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Re: WebDAV interface seems to be broken
Postby RandolphCarter » Mon Mar 31, 2014 2:43 pm
Check the owncloud log. It should contain additional information why the check for WebDAV is exactly failing.
The user which runs php scripts on your system. This depends on the distribution; for Ubuntu that would for example be www-data. See the manual installation documentation for a bit more details.
kyij1
Webserver: Apache
Postby kyij1 » Sun Apr 06, 2014 6:14 am
I already saw those posts before..
But anyhow it was a permissions file (obviously) but it was a parent directory.. /mnt/Raidz2 was chmod'ed 770 but my owncloud data (that I tried to set to 775 was under /mnt/Raidz2/owncloud
That may seem obvious when I say it, but it tripped me up for a few days. Hopefully someone else can benefit.
mophilly
ownCloud version: 5.0.12
Webserver: Apache
PHP version: 5.3.3
Contact:
Re: [SOLVED] WebDAV interface seems to be broken
Postby mophilly » Tue Jul 08, 2014 12:23 am
It is tripping me up. I would be most grateful for a restatement of the required file permissions.
Here is what I have on CentOS 5:
Code: Select all
750 www:www ownCloud (web directory)
770 www:www   data
But should that be like this?
Code: Select all
775 www:www   data
Should the files and folder within the data folder also be set to 775?
TIA.
User avatar
RandolphCarter
ownCloud master
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Tue Jul 08, 2014 12:57 am
Doesn't really matter whether it's 777 or 775 or even 700 - as long as the files belong to the user running php, and that user has read, write (and execute for directories) permissions, it's fine.
Are you still having any specific issues here, or why are you worried?
Please also note that on CentOS, by default SELinux is enabled which can also interfere permission-wise. So if getting "permission denied" or similar messages, it could also be a problem with that.
As for the data directory - yes, all files and folders in that folder need to belong to the www user and have the 7xx permission as well.
Return to “ownCloud Community Edition 6.x”
