Unable to download shared file
ownCloud 6.x reached end of life and is officially unsupported. For details see Wiki page.
Please upgrade your ownCloud.
mattanorak
ownCloud version: 6.0.3
Webserver: Apache
Database: SQLite
OS: Linux Embedded
PHP version: 5.5
Postby mattanorak » Sat Apr 26, 2014 5:28 am
I've had OC running for a few days now and yesterday updated to 6.0.1.2 on my Synology box. I can access files, share, etc, but if I share a file to an external person (one not registered on the system), they get the link, they see "xyz has shared this file with you...." and a link to download it. When clicking on download, they get:
File not found
Firefox can't find the file at https://myservername.co.uk/owncloud/public.php?service=files&t=87d822d823c32e22098584aaf4f25d93&download.
(Same in IE, by the way).
I've searched and found almost similar occurrences, but nothing that quite matches this.
Everything else works up until a user goes to download a file, and then it fails.
I can provide more info if you let me know what you need.
Thanks!
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Unable to download shared file
Postby RealRancor » Sat Apr 26, 2014 1:40 pm
the changelog of the upcoming ownCloud version 6.0.3 contains:
- Fixed "select all" + download on public page
https://owncloud.org/releases/Changelog
So this could fix your problem here.
*gone*
mattanorak
Webserver: Apache
Database: SQLite
OS: Linux Embedded
PHP version: 5.5
Postby mattanorak » Sat Apr 26, 2014 1:50 pm
Ooh, thanks. I'll wait until it becomes a package update for Synology, as the last update went well this way.
Cheers!
mattanorak
Webserver: Apache
Database: SQLite
OS: Linux Embedded
PHP version: 5.5
Postby mattanorak » Fri May 02, 2014 7:13 pm
Just downloaded and installed 6.0.3 and I get the same issue. User is taken to the download page, they click download and they get a page not found error. :(
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri May 02, 2014 7:26 pm
then please report this as a bug to the developers as described here:
viewtopic.php?f=17&t=20688
*gone*
mattanorak
Webserver: Apache
Database: SQLite
OS: Linux Embedded
PHP version: 5.5
Postby mattanorak » Fri May 02, 2014 7:27 pm
I now don't think it's a bug, as I have tried it with someone else and theirs works.
moxyl
Webserver: Apache
PHP version: 5.5.9
Postby moxyl » Tue May 06, 2014 12:00 pm
mattanorak wrote:I now don't think it's a bug, as I have tried it with someone else and theirs works.
Hey ho,
I'm running OC 6.0.3 on a Synology DiskStation as well (DS213+, DSM 5.0-4482) and have the same issues. Additionally, the file download for registred users of my owncloud doesn't work either. Always getting the same error ERR_FILE_NOT_FOUND. I tried changing the rights on DSM and crawled the owncloud log on highest log level, without any success.
So I guess it has something to do with DSM? Which DiskStation and DSM version are you using?
Has anyone ideas how to find the problem or fixing it?
Roadrunner
Webserver: Apache
OS: Linux Embedded
PHP version: 5.5.11
Postby Roadrunner » Tue May 06, 2014 1:18 pm
Same issues on Synology RS2212+ DSM 5.0-4482.
ownCloud installes from original place (no package)
and get the same error.
for example
This webpage is not found
No webpage was found for the web address: https://webaddress/public.php?service=files&t=48216c8fbf86f9875733396fa7e42fa3&download&path=//MS%20Outlook%20anywhere.pdf
even the file exists
Admin log (Everything) don't show any issues in relationship to this error.
Any ideas how to fix it? Thx in advance!
P.S In internet explorer (Save As) the file name is show not as ....anywhere.pdf, but as anywhere_pdf. May be thats the problem?
mattanorak
Webserver: Apache
Database: SQLite
OS: Linux Embedded
PHP version: 5.5
Postby mattanorak » Wed May 07, 2014 9:48 am
I'm running a Synology DS213j with the latest DSM software (5.0-4482), also happened with the previous DSM version, too.
mattanorak
Webserver: Apache
Database: SQLite
OS: Linux Embedded
PHP version: 5.5
Postby mattanorak » Fri May 09, 2014 7:56 pm
Got it. Attention Synology users...
I can't take credit for this, I got the solution from a colleague who pointed me here:
http://sbdomo.esy.es/2014/05/my-reading ... /#more-168
But if you don't speak French, all you need to know is that you need to change the following file:
/etc/httpd/conf/extra/mod_xsendfile.conf-user
to include:
XSendFilePath /volume1
So, my whole mod_xsendfile.conf-user reads like this:
Code: Select all
LoadModule xsendfile_module modules/mod_xsendfile.so
XSendFile on
XSendFilePath /var/services/web /var/services/homes
SetEnv MOD_X_SENDFILE_ENABLED yes
Then issue httpd -k restart to restart the http server, and you're done!
:P
Return to “ownCloud Community Edition 6.x”
Users browsing this forum: Baidu [Spider] and 1 guest
