install OC 6.0.3 on a shared hosting server: problem
ownCloud 6.x reached end of life and is officially unsupported. For details see Wiki page.
Please upgrade your ownCloud.
ratoune
ownCloud version: 6.0.3
Webserver: Apache
OS: Linux Hosting Package
PHP version: 5.3.28
Postby ratoune » Sun May 04, 2014 1:18 am
I've installed OC 6.0.3 on a shared hosting server (Planethoster), via Softaculous.
On the first login, there was this red error message :
"Magic Quotes is enabled. ownCloud requires that it is disabled to work properly."
"PHP modules have been installed, but they are still listed as missing?"
There is a solution there : https://forum.owncloud.org/viewtopic.php?f=8&t=17518
but for me it didn't work.
I've contacted the webhoster, and the response was OC is not compatible with a shared hosting as it is on litepseed. OC will work only on VPS server.
Is it true ?? Is there no way to make OC work on a shared hosting server ? If so, it should be really documented on OC website, as it would be a serious limitation...
Thanks for your help.
Linux x86-64
Apache 2.2.26
MySQL 5.1.73-cll
Php 5.3.28
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Re: install OC 6.0.3 on a shared hosting server: problem
Postby RandolphCarter » Sun May 04, 2014 10:36 am
Although it's not the ideal solution, owncloud is perfectly able to run on many shared hosting setups. Above statement probably should express a limitation of your hoster, not one in general.
hasanus
Postby hasanus » Tue Sep 15, 2015 4:39 pm
I take a shared hosting from inmotionhosting.com But their systems not compatible something. Please look this link:
http://www.inmotionhosting.com/support/community-support/file-management/owncloud-install-via-softaculous
and, this is the error warnings screenshot when i try install OC:
http://i.imgur.com/w4roVjJ.png
what's your suggestion shared hosting company for this issue?
thanks
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Sep 15, 2015 5:35 pm
please create a new thread about your issue in the correct forums instead of resurrecting such an old thread.
*gone*
User avatar
RandolphCarter
ownCloud master
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Tue Sep 15, 2015 5:40 pm
@hasanus you've seen the comments that the hoster posted. If the hoster doesn't support things required for ownCloud, what do you think we can do about that?
Return to “ownCloud Community Edition 6.x”
Users browsing this forum: Baidu [Spider] and 1 guest
