[Solved] - Set httpS URL as trusted_domain in config.php
ownCloud 6.x reached end of life and is officially unsupported. For details see Wiki page.
Please upgrade your ownCloud.
elite711
ownCloud version: 6.0.3
Webserver: Apache
PHP version: 5
Postby elite711 » Wed May 07, 2014 12:59 am
!!! Solution to my problem at the end of this first post !!!
Hi everyone,
I was running oc 6.0.2 perfectly:
- http access through port 8080 => worked perfectly (URL: [url]oc.my_domain.com:8080[/url])
- Then I enabled SSL and did some URL rewriting to force https (no special port so it was 443) => worked perfectly as well (URL: https://oc.my_domain.com)
Them I upgraded to oc 6.0.3 with the "auto-update" available on the admin page and at the end I had this message any people have:
"You are accessing the server from an untrusted domain. [...] If you are an administrator of this instance, configure the "trusted_domain" setting in config/config.php...
Here is what I did to make things work back again with http access through port 8080:
1. I disabled URL rewriting
2. I changed the config.php file and did the following regarding the trusted_domains array:
Code: Select all
'trusted_domains' =>
array ( 0 => 'oc.my_domain.com:8080', ),
3. Just to make sure everything was good, I tried to add a mistake in the URL like adding a 'x' at the beginning like this
Code: Select all
array ( 0 => 'xoc.my_domain.com:8080', ),
and indeed I got the error message again.
Then I decided to set URL rewriting back to force the use of https:
1. I re-enabled URL rewriting the way it was set before upgrading
2. I edited the config.php file to make it look like this:
Code: Select all
array ( 0 => 'oc.my_domain.com:8080', 1 => 'https://oc.my_domain.com' ),
but it didn't work.
3. I tried to escape the double // from the quotes by writing it like this:
Code: Select all
1 => 'https:\/\/oc.my_domain.com'
but it didn't work.
So my question is, how to define the https URL as a trusted_domain?
Thank you for your time. Do not hesitate if you have any question.
Have a great day, Roger.
!!! Solution !!!
Ok, I was trying to make something simple complicated...
Here is how my config.php file now looks like:
Code: Select all
  array (
    1 => 'oc.my_domain.com',
First I allowed the :8080 domain, then because there is URL-rewriting to force httpS I allowed the generic domain (as Rancor suggested) and everything works well =)
Thank you again Rancor!!
PS: I left the comma at the end as it is in the original config.php file and it works
elite711
Webserver: Apache
PHP version: 5
Re: Set httpS URL as trusted_domain in config.php
Postby elite711 » Wed May 07, 2014 1:02 am
I am leaving my computer up and running for the moment.
If you try to connect to my site using this url: [url]oc.my_domain.com:8080[/url] you will be redirected to the https site but the :8080 will still remain so delete it from the re-writed URL and press ENTER again to have the "trusted_domain" error message appear.
I have to redo my url-rewriting rule to delete the port.
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed May 07, 2014 7:39 am
please see
viewtopic.php?f=17&t=20220
for the correct syntax of multiple domains. You also dont't have to include the https
*gone*
elite711
Webserver: Apache
PHP version: 5
Postby elite711 » Wed May 07, 2014 9:45 am
thank you for your quick answer. However I already went through the topic you sent before posting my message => without success.
Here is what worked well for http access through port 8080:
Code: Select all
'trusted_domains' => array('oc.my_domain.com:8080', ),
Code: Select all
'trusted_domains' => array ( 0 => 'oc.my_domain.com:8080', ),
Then I re-enabled url-rewriting to force the use of https and edited the trusted domain list.
First I tried:
Code: Select all
'trusted_domains' => array('oc.my_domain.com:8080', 'https://oc.my_domain.com', ),
=> Didn't work.
Then I tried the same but with escaping the // with \:
Code: Select all
'trusted_domains' => array('oc.my_domain.com:8080', 'https:\/\/oc.my_domain.com', ),
=> Didn't work.
Then I tried the following:
Code: Select all
'trusted_domains' => array ( 0 => 'oc.my_domain.com:8080', 1 => 'https://oc.my_domain.com', ),
=> Didn't work.
Again, I tried escaping the // with \:
Code: Select all
'trusted_domains' => array ( 0 => 'oc.my_domain.com:8080', 1 => 'https:\/\/oc.my_domain.com', ),
=> Didn't work.
Without specifying the httpS URL as a trusted URL I still have the error message! =(
Any further Idea? Anyone accessing oc 6.0.3 through https, could you copy your trusted_domain line here to see how you did (or any other trick to make https work fine)?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed May 07, 2014 12:37 pm
only using https and this works for me in 6.0.3:
'trusted_domains' => array('cloud.example.com'),
*gone*
elite711
Webserver: Apache
PHP version: 5
Postby elite711 » Wed May 07, 2014 2:25 pm
Alright, I'll try again tonight and I'll update my post.
Actually thinking about it I should probably add a second line without the 8080 port like this (taking into consideration it works fine through https for you):
Code: Select all
'trusted_domains' => array('oc.my_domain.com:8080', 'oc.my_domain.com', ),
Code: Select all
'trusted_domains' => array ( 0 => 'oc.my_domain.com:8080', 1 => 'oc.my_domain.com', ),
Cheers,
Roger
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed May 07, 2014 2:53 pm
use your first posted example. But there is a syntax error in it (one comma too much). Please compare it with the linked FAQ.
*gone*
Return to “ownCloud Community Edition 6.x”
