Can't use mysqli.so php extension
ownCloud 6.x reached end of life and is officially unsupported. For details see Wiki page.
Please upgrade your ownCloud.
michaudg
ownCloud version: 6.0.3
Webserver: nginx
PHP version: 5.5
Postby michaudg » Sun May 25, 2014 8:42 pm
I'm trying to use mysqli.so php extension with ownCloud 6.0.3 but i receive this message :
No database drivers (sqlite, mysql, or postgresql) installed.
I see in lib/private/util.php that ownCloud only check for mysql extension but not for mysqli or for pdo_mysql :
and !is_callable('mysql_connect')
If i add and !is_callable('mysqli_connect'), it works but i'm not sure that ownCloud will like that.
If i uncomment ;extension=mysql.so in php.ini, all works correctly.
I'm i doing something wrong? Do ownCloud support mysqli driver?
Thank you.
ArchLinux
NGINX 1.6.0
PHP 5.5.12
ownCloud 6.0.3
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Can't use mysqli.so php extension
Postby RealRancor » Sun May 25, 2014 9:20 pm
according to:
https://stackoverflow.com/questions/639 ... ql-connect
mysql_connect and mysqli_connect are not interchangeable so you can't use mysqli_connect. However you could request this as a feature at the bugtracker like described here:
viewtopic.php?f=17&t=20687
*gone*
Return to “ownCloud Community Edition 6.x”
