"don't have permission" on local mounted shares
Ask all your questions regarding OC 7.x Please read the Support Forum Rules
ownCloud 7.x will be end of life soon. See maintenance and release schedule for more details.
Time to upgrade!
oneseventeen
ownCloud version: 5.0.9
Webserver: Apache
PHP version: 5.4.6
Postby oneseventeen » Tue Aug 12, 2014 7:29 pm
I use the "External Storage" app to add Local storage for each user individually, so for Luke, it looks like this:
  • Folder Name: SyncData-Luke
  • External Storage: Local
  • Configuration: /mnt/luke
  • Available for: Luke Skywalker
/mnt/luke is a cifs mounted volume.
This worked beautifully until I attempted using fstab to manage my cifs mounts. I still use the uid=www-data and gid=www-data, so /mnt/luke has the following permissions:
Code: Select all
drwxr-xr-x 2 www-data www-data    0 Aug  8 08:25 luke
When logged in as root, I can traverse these folders, create files, etc. without issue. Via owncloud, I cannot view or edit the data. I see the following at the top of my screen:
Owncloud Error wrote:You don't have permission to upload or create files here
What confuses me, is I have unmounted, rebooted, then mounted again using the exact same cifs mount command that worked beautifully before. The only differences are:
  1. I mounted the volume after the local storage was created
  2. I have cifs-utils installed, where I previously did not
I have attempted uninstalling cifs-utils, removing the External Storage config from the OwnCloud admin settings, mounting the way I had previously, and re-adding it via the OwnCloud admin settings, and still I receive the same results.
Any thoughts?
One final test:
  1. I unmounted /mnt/luke
  2. I changed the permissions to 777 on /mnt/luke
  3. I refreshed my owncloud page only to see the same permissions error
Perhaps I need to force owncloud to refresh permissions data?
oneseventeen
Webserver: Apache
PHP version: 5.4.6
Re: "don't have permission" on local mounted shares
Postby oneseventeen » Tue Aug 12, 2014 8:34 pm
Wow, I'm such a noob!
Permissions were updated after I unmounted the volume in owncloud, so all I needed to do was rescan the filesystem based on the instructions on this page:
http://sharadchhetri.com/2013/11/14/how ... wncloud-5/
The specific solution for me (because I don't have billions of records in my file cache table yet) was:
Code: Select all
php /var/www/owncloud/console.php files:scan --all
All is well!
Also, because all of my shared folders begin with Users or Share, I likely could have just deleted all lines from the oc_filecache table that begin with Users or Share.
Thanks for taking the time to read, I hope my solution helps someone else out!
jeroen94704
ownCloud version: 7.0.3
Webserver: Apache
Postby jeroen94704 » Wed Jan 21, 2015 5:02 pm
oneseventeen wrote:I hope my solution helps someone else out!
It did. Thank you :)
Jeroen
Return to “ownCloud Community Edition 7.x”
