Use USB SSD - .ocdata not found
Ask all your questions regarding OC 7.x Please read the Support Forum Rules
ownCloud 7.x will be end of life soon. See maintenance and release schedule for more details.
Time to upgrade!
JamesGeddes
Webserver: Apache
Postby JamesGeddes » Mon Apr 04, 2016 9:16 pm
Hi everyone,
I am trying to set up a Raspberry Pi as a file server with OwnCloud. Clearly, 8gb is not a lot of capacity these days, so I've got a lovely, big SSD to store all of my junk on. Unfortunately, telling OwnCloud to use it appears to be a moderately complex task.
Research
Thus far I have been working through the following;
  1. Owncloud how to set/change data directory by diegoarango91
  2. file ".ocdata" missing from diegoarango91
  3. How to set/change data directory by RandolphCarter
Even though they are great, I still haven't had much luck fixing this issue so far!
OwnCloud should start saving data to my USB SSD
When I set the datadirectory in config.php from the default
Code: Select all
'datadirectory' => '/var/lib/owncloud/data/',
to the directory that I actually want it to use (the directory where my USB SSD is mounted)
Code: Select all
 'datadirectory' => '/mnt/usb/ocdata/data',
the following error is returned, when I go to my OwnCloud home
Screen Dump
The .ocdata file is actually in the root of the new directory, so I have no idea why OwnCloud is having difficulty seeing it.
Additionally, when I try to change ownership using
Code: Select all
chown -R www-data:www-data /mnt/usb/ocdata
I get
Code: Select all
Operation not permitted
Operating system: Raspbian Jessie
Web server: Apache2
PHP version: 5.6.19
ownCloud version (see ownCloud admin page): 7.0.4.2
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption):n): none - trying to configure USB storage though!
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Use USB SSD - .ocdata not found
Postby RealRancor » Mon Apr 04, 2016 9:31 pm
that might be caused by wrong permissions. Have a look at viewtopic.php?f=29&t=34852#p112151 for some pointers.
You should also note that oC 7.0.4 is outdated (7.0.13 is current) and will reach end-of-life soon (see red box above).
*gone*
JamesGeddes
Webserver: Apache
Postby JamesGeddes » Mon Apr 04, 2016 9:50 pm
Well that raises two questions;
  1. How do I upgrade to the latest version of OwnCloud?
    I used the following command to install OwnCloud
    Code: Select all
    apt-get install owncloud
  2. How do I mount the USB drive so that it belongs to www-data and has the correct permissions?
    I have looked at the link you provided, as well as the links it provides, but cannot work it out. I will happily admit that I'm an OCn00b!
Clearly, I'd like to get it working first, then I'll worry about upgrading.
Thanks!
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Mon Apr 04, 2016 9:53 pm
install instructions are available here:
https://doc.owncloud.org/server/9.0/adm ... tallation/
For the linux basics you should ask at a community dedicated to your used linux distribution.
*gone*
JamesGeddes
Webserver: Apache
Postby JamesGeddes » Mon Apr 04, 2016 9:56 pm
Why is this so difficult on OwnCloud? It's super simple with DropBox...
Also, if I go to the Raspberry Pi boards, they will probably tell me to go ask the OwnCloud boards!
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Mon Apr 04, 2016 9:58 pm
Because Dropbox is doing the work for you. And ownCloud is self-hosted and at least requires some linux basics.
*gone*
JamesGeddes
Webserver: Apache
Postby JamesGeddes » Tue Apr 05, 2016 4:44 pm
I solved the problem - by using SyncThing! Much easier to set up and much faster, peer to peer synchronisation.
Return to “ownCloud Community Edition 7.x”
