Windows desktop client does not download large files
Ask all your questions regarding OC 7.x Please read the Support Forum Rules
ownCloud 7.x will be end of life soon. See maintenance and release schedule for more details.
Time to upgrade!
poweredge
ownCloud version: 7.0.13
Webserver: Apache
OS: Windows Server
PHP version: 5.4.45
Postby poweredge » Tue May 03, 2016 11:08 am
The win client uploads fine any kind of file on the server.
When the other clients try to download the large file (>80Megs), on the server side apache crashes with an apache error like this:
[Mon May 02 12:48:28.557784 2016] [:error] [pid 5208:tid 1104] [client xxx.xxx.xxx.xxx:58727] PHP Fatal error: Out of memory (allocated 75759616) (tried to allocate 73138176 bytes) in C:\\Apache24\\htdocs\\3rdparty\\sabre\\dav\\lib\\Sabre\\HTTP\\Response.php on line 164
PHP has 1G memory limit and 2G for post_max_size and upload_max_filesize
Download from webUI and android work fine.
Operating system: Windows 2008
Web server: Apache 2.4
PHP version: 5.4.45
ownCloud version (see ownCloud admin page): 7.0.13
Thank you in advance for help.
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Windows desktop client does not download large files
Postby RealRancor » Tue May 03, 2016 11:22 am
the message:
Code: Select all
is telling you that you have configured a memory limit of 75759616 bytes which are around 72MB. This is far below the absolute minimum of 128MB required for ownCloud.
*gone*
poweredge
Webserver: Apache
OS: Windows Server
PHP version: 5.4.45
Postby poweredge » Tue May 03, 2016 12:06 pm
RealRancor wrote:Hi,
the message:
Code: Select all
Good morning, thnx for the reply.
I have set the memory limit to 1G, in php.ini and .htaccess in owncloud folder.
Maybe is there any other setting to do?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue May 03, 2016 12:46 pm
It probably needs to be configured in your main php.ini. You can have a look at the PHP manual for more info about that setting and how to configure it:
https://secure.php.net/manual/en/ini.co ... mory-limit
*gone*
poweredge
Webserver: Apache
OS: Windows Server
PHP version: 5.4.45
Postby poweredge » Fri May 06, 2016 2:17 pm
Good news!
I've fixed the issue adding "OWNCLOUD_CHUNK_SIZE=1000000" in owncloud.cfg
Regards
G
Return to “ownCloud Community Edition 7.x”
