ownCloud 5.0.12 (up to date) won't update??
Ask all your questions regarding OC 7.x Please read the Support Forum Rules
ownCloud 7.x will be end of life soon. See maintenance and release schedule for more details.
Time to upgrade!
dashpuppy
ownCloud version: 5.0.0
Webserver: proprietary
Postby dashpuppy » Thu Jun 09, 2016 7:17 pm
I have a vm downloaded from https://www.turnkeylinux.org/owncloud and it's stating its up to date but when i install new client on my desktop it says it's outdated and not supported.
How do i update this then to the current version ? Do i need to backup data then re-doe it all over again ?
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Re: ownCloud 5.0.12 (up to date) won't update??
Postby tflidd » Fri Jun 10, 2016 10:31 am
You need to do a backup anyway.
To upgrade, you can't skip a major version, so you have to go: 5.0.12 -> 6.0.x -> 7.0.x -> 8.0.x -> 8.1.x -> 8.2.x -> 9.0.x
(for x always use the latest version, you can get them from owncloud.org/changelog, the link for OC 6 is currently broken, see link here: https://github.com/owncloud/core/issues ... -208935582)
Do manual upgrades, they are more reliable. After each upgrade, open the webinterface, activate your apps and make sure everything is fine. You don't have to run all the upgrades at one time but I would at least go so far to reach a currently supported version (8.0 and later).
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Jun 10, 2016 11:32 am
Choose the official appliance from:
https://owncloud.org/install/#instructions-server
instead which brings you a recent installation instead of such a outdated 3rdparty VM
*gone*
Return to “ownCloud Community Edition 7.x”
