Install error message - "PHP module zip not installed"
Please upgrade your ownCloud.
azietara
Webserver: Apache
PHP version: 5.3.21
Postby azietara » Fri Apr 05, 2013 6:45 am
I am using a hosted web service, followed the server installation instructions but get the message "PHP module zip not installed" when I go to configure. I can't find any reference to this error, and the tools script suggests that all appropriate zip modules are installed.
Any ideas? Install details below.
Thanks,
Andrew
Environment: Apache/2.2.23 (Unix) mod_ssl/2.2.23 OpenSSL/1.0.0-fips mod_bwlimited/1.4 mod_perl/2.0.6 Perl/v5.10.1
Server: x86_64 linux
Database: mySQL 5.1.66-cll
Client: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:20.0) Gecko/20100101 Firefox/20.0
OC-Version: Server 5
PHP-Version: 5.3.21
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Install error message - "PHP module zip not installed"
Postby RealRancor » Fri Apr 05, 2013 8:18 am
check with the phpinfo.php like described here:
viewtopic.php?f=17&t=7304
that the module is installed and if not ask your hoster to install it.
*gone*
azietara
Webserver: Apache
PHP version: 5.3.21
Postby azietara » Fri Apr 05, 2013 8:37 am
Thanks, did that - it looks like the zip modules are installed (see output below). My service provider also tells me that they are installed as well.
BZip2 Support Enabled
Stream Wrapper support compress.bzip2://
Stream Filter support bzip2.decompress, bzip2.compress
BZip2 Version 1.0.5, 10-Dec-2007
Phar: PHP Archive support enabled
Phar EXT version 2.0.1
Phar API version 1.1.1
SVN revision $Id: 7b7d559811a842dc9e7d33777a8f993aa2b9933d $
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression enabled
OpenSSL support enabled
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Apr 05, 2013 8:50 am
"ZIP-based phar archives enabled" and "BZip2" is not Zip. You need an output like this:
zip
Zip enabled
Extension Version $Id: 727cc853ca1ae15d995c3520c5719784ddc1e292 $
Zip version 1.11.0
Libzip version
if you cant find this in the phpinfo ask your hoster.
*gone*
azietara
Webserver: Apache
PHP version: 5.3.21
Postby azietara » Fri Apr 05, 2013 9:05 am
Thanks again. Forgive my ignorance, but what should I specifically ask the hosted to install? The php zip module? Is there a specific version required?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Apr 05, 2013 9:29 am
Mhhh, probably an installations is not needed as i found out a few minutes ago. Seems that php must be compiled with a special flag:
http://www.php.net/manual/en/zip.installation.php
because the Zip module is directly installed into PHP on a standard installation. But your hoster should know what he has to do here.
*gone*
azietara
Webserver: Apache
PHP version: 5.3.21
Postby azietara » Wed Apr 10, 2013 11:42 am
Alright, figured it out. My host wouldn't install the required module on the shared hosting plan I'm on (Crazy Domains for anybody having the same problem).
So, I downloaded the full install and uploaded via FTP. Then I simply commented out the checking for the zip module in the util.php file (in owncloud/lib starting at line 219) and it works like a charm. I presume I won't be able to create an archive copy of files for export or view zip files, but as I own the site this isn't a problem.
Users browsing this forum: No registered users and 4 guests
