403 on *Dav services
Please upgrade your ownCloud.
DokktorRavenstein
Contact:
Postby DokktorRavenstein » Tue Mar 20, 2012 3:21 pm
Hi guys,
I installed owncloud on my VPS this morning and spent ages wondering why I was getting 403 errors every time I tried to access one of the DAV services from my desktop machine. I scoured the forum and found a couple of topics that were similar, but the solutions did not help.
I eventually found the following lines in my apache config
Code: Select all
               <LimitExcept GET POST OPTIONS>
                       Order deny,allow
                        Deny from all
               </LimitExcept>
These lines are in the apache configuration for debian-esque operating systems by default and essentially stop apache from accepting requests that are not GET POST or OPTIONS. I disabled these lines by commenting them out.
If anyone else is experiencing the 403 Restricted bug, this might be the answer. I was wondering if there is anything that could be added to the owncloud .htaccess file to prevent this problem or at the very least if a warning about this could be added to the support wiki?
Edit: apologies if this is the wrong place for me to post this message.
jackieloh
Re: 403 on *Dav services
Postby jackieloh » Sat May 12, 2012 3:05 pm
you can edit vhost configuration apache same http://www.howtoforge.com/how-to-set-up ... buntu-8.10. (See 3.) It work for me .I use netdrive and can copy onto host.
User avatar
interfaSys
Starter
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5
Contact:
Postby interfaSys » Wed Jan 29, 2014 6:48 pm
In some hosting environment which restrict what you can do, you may need to customise the virtualhost
Code: Select all
<Directory /your/docroot>
        <Limit GET POST OPTIONS PROPFIND PUT DELETE MKCOL MOVE>
                Order allow,deny
                Allow from all
        </Limit>
        <LimitExcept GET POST OPTIONS PROPFIND PUT DELETE MKCOL MOVE>
                Order deny,allow
                Deny from all
        </LimitExcept>
</Directory>
PUT is to send files
DELETE is to delete elements
MKCOL is to create folders
MOVE is to move elements
Cheers,
Olivier
Consultant @ interfaSys
Maintainer of Gallery+ https://apps.owncloud.com/content/show.php?content=169116
