SQlite database access
Please upgrade your ownCloud.
hyph
Postby hyph » Thu Apr 12, 2012 1:08 pm
Not really knowing sqlite, I would be interested in getting SQL access to the DB created by owncloud.
Is it the file below subdir 'data': owncloud.db ?
Trying to "open" that with sqlite commandline tool says: no db or encrypted !?
After having access, I will try to figure out how to delete a group, which seems not to be possible in GUI!?
A proper SQL statement for that would be appreciated.
Thanks!
tschoie
Beginner
Re: SQlite database access
Postby tschoie » Fri Apr 13, 2012 12:20 am
Hi there,
hyph wrote:Not really knowing sqlite, I would be interested in getting SQL access to the DB created by owncloud.
Yes.
hyph wrote:Trying to "open" that with sqlite commandline tool says: no db or encrypted !?
Thanks!
I don't have any experience with the command line shell for SQlite, but one problem I could think of is file permissions. Did you make sure you have read/write permission for said file?
Other than that, I can only say I used SQLite Manager, a Firefox add-on (https://addons.mozilla.org/de/firefox/a ... e-manager/) to access the database and it worked really well.
Cheers,
tschoie
hyph
Postby hyph » Sun Apr 15, 2012 2:37 am
I tried to open it as root:
root@...:/var/www/owncloud/data# sqlite owncloud.db
Unable to open database "owncloud.db": file is encrypted or is not a database
But you are right, with the SQLite Manager addon, the file opens without problems.
And I was able to remove the group (and afterwards the assignments of users to that group - it seems SQLite does not manage foreign key constraints? Or owncloud does not use them?)
Thanks a lot!
User avatar
DarkSpider
Beginner
Postby DarkSpider » Sun Apr 15, 2012 5:39 pm
Have you tried:
"sqlite3 owncloud.db" ?
It looks like a wrong sqlite client version.
check the version with:
"sqlite3 --version" or "sqlite --version"
my version is: 3.6.20
btw: I found two interesting links about sqlite commands: http://www.pantz.org/software/sqlite/sqlite_commands_and_general_usage.html
and
http://www.sqlite.org/draft/sqlite.html
