Howto get a calendar content as .ics file
Please upgrade your ownCloud.
eMarcus
Helpful Elf
Postby eMarcus » Thu Jun 28, 2012 3:29 pm
I know how to export my calendar as an .ics file using the web interface, but I would like to do that automatically, so that I would frequently grab my calandar and store it in an .ics file for (ics) applications to use it.
any idea how to do that?
Thanks,
bye
Marcus.
User avatar
tanghus
Starter
Re: Howto get a calendar content as .ics file
Postby tanghus » Thu Jul 05, 2012 12:00 pm
I download my calendar(s) regularly using wget: http://tanghus.net/2012/04/backup-owncl ... -contacts/
FordPrefect
Helpful Elf
Postby FordPrefect » Sat Jul 07, 2012 12:42 am
tanghus wrote:I download my calendar(s) regularly using wget: http://tanghus.net/2012/04/backup-owncl ... -contacts/
Followed your instructions, but doesn't work for me :-(
Firstly the parameter is called
Code: Select all
... --http-passwd= ...
in my version of wget. And then, owncloud seems to send back a http page rather than the calendar or contacts file. I'm using v4.04 by the way. Which version are you using? Does this method still work on v4.04?
FordPrefect
Helpful Elf
Postby FordPrefect » Sat Jul 07, 2012 2:04 pm
OK, I have managed to make that work for me. Not sure if there are different "dialects" of wget around, but for me it works following tanghus description, but with modifications as follows:
1. The download script
Code: Select all
#!/bin/sh
DATE=`date +"%Y-%W"`
# Download and gzip contacts.
wget --auth-no-challenge --no-clobber \
  -O $HOME/pimdata_backup/contacts-$DATE.vcf "http://<server-path to owncloud>/?app=contacts&getfile=export.php?bookid=<number>"
gzip -f $HOME/pimdata_backup/contacts-$DATE.vcf
# Download and gzip calendar.
  -O $HOME/pimdata_backup/calendar-$DATE.ics "http://<server-path to owncloud>/?app=calendar&getfile=export.php?calid=<number>"
gzip -f $HOME/pimdata_backup/calendar-$DATE.ics
Needless to say, but you have to replace <server-path to owncloud> and <number> with your specific values. Please mind the differences to tanghus description. For one, as he pointed out on his page, I left out any user/password information, which makes the script more generic. And secondly, please mind the quote characters around the URL. Without them, the URL was not parsed in its wholeness.
2. a .netrc file holding the access information
Code: Select all
machine <server-name> login <username> password <password>
This file needs to be stored in your home directory. My wget command automatically picks it up from there.
Dear Windows users: I have no idea of an equivalent Windows approach, sorry. Thanks tanghus for that nice approach! Now storing my data regularly by means of a cron job.
dcarrco
Beginner
ownCloud version: 6.0.3
Webserver: Apache
Database: SQLite
Postby dcarrco » Wed Jul 09, 2014 6:32 pm
i have been using this method to backup my calendar and contacts in a cron job. works great and has saved me a few times when my owncloud went down. unfortunately in the last few weeks it has stopped working. i am getting a "GnuTLS: A TLS warning alert has been received." error returned from the wget command.
my wget line is
Code: Select all
wget --auth-no-challenge --no-check-certificate  \
      -O contacts.vcf "https://myserver.com/owncloud/?app=contacts&getfile=export.php?bookid=1"
(i added the --no-check-certificate in order to try to solve the problem. i also tried to specify SSL and not TLS). i read that there may have been a change in the wget. anyone have any ideas?
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Jul 09, 2014 7:48 pm
as ownCloud is served by your Webserver you might want to ask such questions related to used tools or webservers on a linux specific forums where you probably get better answers on such non-ownCloud related questions.
*Edit*
Ah, just saw that you have already fixed this issue in wget:
viewtopic.php?f=26&t=22189
*gone*
dcarrco
Beginner
Webserver: Apache
Database: SQLite
Postby dcarrco » Fri Jul 11, 2014 2:05 am
its true, owncloud is served by my webserver. i did figure it out, thankfully. however it seems disingenuous and certainly not helpful to direct me to linux or apache forums. i guess maybe they would direct me to AMD because that's who made my processor, or maybe i should talk to my ISP because after all my internet comes through them?
if you dont know the answer or anything helpful, thats fine. passing me on to other folks who will undoubtedly say "owncloud is a complicated piece of software, better ask over there" is just pointless. i feel i posted my question in a thread that was very much in context. it is truly owncloud related, as it has to do with retrieving my owncloud stored data from an owncloud program layer which just happens to be on top of an apache server.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Jul 11, 2014 7:17 am
Hu,
as SSL/TLS stuff is not handled by ownCloud (luckily it doesn't implement this transport layer) but by your webserver it should be clear that forums dedicated to such software are definitely the best place to ask this. ;)
Anyway. You found this problem in wget and got this to work.
*gone*
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Fri Jul 11, 2014 8:06 am
i did figure it out
Would you be so kind as to post the solution? So that future users coming here from a search engine or the like might also know how to solve it easily; that would be awesome!
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Jul 11, 2014 8:41 am
see the link above :)
https://forum.owncloud.org/viewtopic.php?f=26&t=22189
The user had to recompile a specific wget version which shows me that a linux specific forums where indeed the best pointer.
*gone*
