nginx error: "server" directive is not allowed here
Please upgrade your ownCloud.
timm
Postby timm » Tue Aug 07, 2012 12:03 am
I'm trying to get owncloud running with nginx on my raspberry pi, since apache seems a little over-sized. I installed nginx and copied and modified the text from the owncloud page into nginx.conf and installed the server certs as per instructions. However, the server won't start and gives me a rather vague error message
nginx: [emerg] "server" directive is not allowed here in /usr/local/nginx/conf/nginx.conf:100
about its config file. Line 100 is where the owncloud part starts. Can somebody help me out here, please?
Code: Select all
user www-data;
worker_processes 4;
pid /var/run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        tcp_nodelay on;
        keepalive_timeout 65;
        types_hash_max_size 2048;
        # server_tokens off;
        # server_names_hash_bucket_size 64;
        # server_name_in_redirect off;
        include /etc/nginx/mime.types;
        default_type application/octet-stream;
        # Logging Settings
        access_log /var/log/nginx/access.log;
        error_log /var/log/nginx/error.log;
        # Gzip Settings
        gzip on;
        gzip_disable "msie6";
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript;
        # nginx-naxsi config
        # Uncomment it if you installed nginx-naxsi
        #include /etc/nginx/naxsi_core.rules;
        # nginx-passenger config
        # Uncomment it if you installed nginx-passenger
        #passenger_root /usr;
        #passenger_ruby /usr/bin/ruby;
        # Virtual Host Configs
        include /etc/nginx/conf.d/*.conf;
        include /etc/nginx/sites-enabled/*;
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
################### Owncloud
# redirect http to https.
server {
  listen 80;
  server_name apahatchi.homeip.net;
  rewrite ^ https://$server_name$request_uri? permanent;  # enforce https
# owncloud (ssl/tls)
 server {
  listen 443 ssl;
  ssl_certificate /etc/nginx/certs/server.crt;
  ssl_certificate_key /etc/nginx/certs/server.key;
  root /var/www/owncloud;
  index index.php;
  client_max_body_size 1000M; # set maximum upload size
  # deny direct access
  location ~ ^/(data|config|\.ht|db_structure\.xml|README) {
    deny all;
  # default try order
  location / {
    try_files $uri $uri/ @webdav;
  # owncloud WebDAV
  location @webdav {
    fastcgi_split_path_info ^(.+\.php)(/.*)$;
    fastcgi_pass 127.0.0.1:9000; # or use php-fpm with: "unix:/var/run/php-fpm/php-fpm.sock;"
    fastcgi_params HTTPS on;
    include fastcgi_params;
  # enable php
  location ~ \.php$ {
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: nginx error: "server" directive is not allowed here
Postby RealRancor » Tue Aug 07, 2012 12:45 am
as you can read here:
http://wiki.nginx.org/HttpCoreModule#server
the "server" directive has to be in the "http" directive and no outside of it.
*gone*
timm
Postby timm » Tue Aug 07, 2012 1:09 am
Thank you, Rancor, that fixed it.
Funnily enough nginx now complains about the lines
Code: Select all
. If I out-comment them, it seems to work.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Aug 07, 2012 11:35 am
Ok, then just try to add this:
Code: Select all
fastcgi_param   HTTPS                   $https;
to your /etc/nginx/fastcgi_params
*gone*
timm
Postby timm » Tue Aug 07, 2012 11:14 pm
Thanks again. I had
Code: Select all
fastcgi_param  HTTPS              $https if_not_empty;
in there anyway. Not much of a difference, I suppose?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Aug 07, 2012 11:41 pm
That depends on your NginX version / packager. I remember that i had such a problem which the debian packages from dotdeb.org, but it was fixed in an update.
*gone*
timm
Postby timm » Wed Aug 08, 2012 12:17 am
I compiled it myself, it's the latest version. So no packager but myself to blame :)
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Aug 08, 2012 10:51 am
Ok, i don't know how to fix this issue. But that's an NginX issue and not really a problem with OwnCloud so just try to ask your question on the NginX forums:
http://nginx.org/en/support.html
*gone*
timm
Postby timm » Wed Aug 08, 2012 11:43 am
Thanks, but you got me wrong, it actually works (tm) now :)
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Aug 08, 2012 12:43 pm
Ah, sorry. :oops: :D
*gone*
Users browsing this forum: Bing [Bot] and 3 guests
