Error Creating User - User Already Exists
Please upgrade your ownCloud.
cejack4
ownCloud version: 4.5.5
Postby cejack4 » Thu Jan 03, 2013 2:13 am
I get the following error code when trying to enter a user in the Settings / Users administrative section of Owncloud:
"Error Creating User - User Already Exists"
I have Ajaxplorer (a similarly competitive open source file sharing facility) on this same system (raspberry pi) and it works clean as a whistle and I can add users and administrative accounts all day long.
I can kind of presume that there are some kind of permission or ownership problems here but I am admittedly poor with Linux permissions / ownership. Any guides, recommendations or suggestions for this particular problem adding users are welcome.
I can login and get access to the Owncloud server with the root login. However, that is the only user I can provision at the present time.
Specs:
Running Owncloud 4.5.5 on Raspberry pi. Using Debian Squeeze via Squeezeplug.
http://www.squeezeplug.de/
8GB Class 6 SD Card.
2TB external USB Drive.
Headless setup with OpenSSH.
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Re: Error Creating User - User Already Exists
Postby RandolphCarter » Thu Jan 03, 2013 2:26 am
There was a report of this problem a little while ago (see this thread). It was never resolved, though unfortunately, but maybe you can get some inspiration there? Is there anything in the logs?
cejack4
Postby cejack4 » Thu Jan 03, 2013 3:21 am
Nothing in the logs when I do this. Just some stuff when I was monkeying around with Vcards in the contacts folder but that does not appear to be anything to do with the lack of ability to create users.
cejack4
Postby cejack4 » Thu Jan 03, 2013 10:25 am
Just fixed this by an owncloud re-install running SqueezePlug.
This seems to have done the trick and I did not use "root" as administrative user name. I'm presuming this may have had something to do with my previous failure. Not sure but thought I'd share.
I still find Linux permissions and ownership massively confusing...
Christmas
Postby Christmas » Wed Jan 09, 2013 11:31 am
i solved the problem...
disable webdav and it will work
User avatar
RandolphCarter
ownCloud master
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Wed Jan 09, 2013 12:27 pm
The message in such a case is quite confusing and in my opinion should be changed (no idea if that's easily possible though). Anybody willing to report an issue for it on github?
