fail2ban regex for Owncloud 8
iskear
ownCloud version: 8.0.0
Webserver: nginx
OS: Unknown
PHP version: latest
Postby iskear » Tue Feb 10, 2015 8:55 pm
I just updated to Owncloud 8 and it's working great, except fail2ban doesnt detects anything anymore. I looked into the logs and saw that oc appeared to have changed the logging format again. Now my question, since the release is so fresh I simply dont find a working regex for fail2ban so that the new format:
Code: Select all
{"reqId":"a3afd43234a09a087b785acf835facca","remoteAddr":"10.0.0.20","app":"core","message":"Login failed: 'a' (Remote IP: '10.0.0.20', X-Forwarded-For: '')","level":2,"time":"2015-02-10T19:30:14+01:00","method":"POST","url":"\/"}
is getting found accordingly.
I'm myself not skilled enough getting something to work, but I tried:
Code: Select all
{"reqId":".*","remoteAddr":".*","app":"core","message":"Login failed: '.*' \(Remote IP: '<HOST>', X-Forwarded-For: '.*'\)"
,"level":2,"time":".*","method":"POST","url":"\/"}
This unfortunatly doesn't work.
In contrast, the one for 7.0.4 looked like that:
Code: Select all
{"app":"core","message":"Login failed: '.*' \(Remote IP: '<HOST>', X-Forwarded-For: '.*'\)","level":2,"time":".*"}
Maybe you can help, thank you in advance
MarkG
Webserver: Apache
PHP version: 5.5
Re: fail2ban regex for Owncloud 8
Postby MarkG » Tue Feb 10, 2015 11:06 pm
Yikes! Thanks for the tip that fail2ban is broken. I just upgraded on Sunday and did not think to test that.
Chakalov
ownCloud version: 8.0.2
Webserver: nginx
Postby Chakalov » Wed Feb 11, 2015 12:03 am
You were actually pretty close! Here's the working regex:
Code: Select all
{"reqId":".*","remoteAddr":".*","app":"core","message":"Login failed: '.*' \(Remote IP: '<HOST>', X-Forwarded-For: '.*'\)","level":2,"time":".*"}
At least that's working just fine with my new 8.0.0.2 version of ownCloud.
Let me know if it worked for you as well
MarkG
Webserver: Apache
PHP version: 5.5
Postby MarkG » Wed Feb 11, 2015 4:02 am
Iskear, thanks again for the heads up, and Chakalov, thank you for the fix!
I can confirm:
1) the regex that worked for fail2ban with 7.0.4 indeed failed with 8.0.0, and
2) the fix above works for me on ownCloud 8.0.0-5 with fail2ban 0.8.11 on Linux Mint 17.1.
iskear
Webserver: nginx
OS: Unknown
PHP version: latest
Postby iskear » Wed Feb 11, 2015 7:52 pm
Thank you very much, I tested your filter and it worked!
Greatings, Iskear
Trevelian
Beginner
Webserver: Apache
PHP version: 5.4.37
Postby Trevelian » Wed Feb 11, 2015 8:01 pm
Hello :)
failregex={.*Login failed:.*IP: '<HOST>',.*"}
Work for both version.
MarkG
Webserver: Apache
PHP version: 5.5
Postby MarkG » Wed Feb 11, 2015 11:32 pm
Trevelian wrote:Work for both version.
I prefer to be more specific, and not make things like DoS attacks too easy. With that regex, try logging with a userid like "IP: 'localhost'". HOST would be parsed out as localhost. In the log entries, the unfiltered user input userid immediately follows the "Login failed:" string.
artemicion
Starter
Webserver: Apache
Postby artemicion » Tue Mar 10, 2015 3:48 pm
Chakalov wrote:Hi,
Code: Select all
This got it working for me! Thank you! :)
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed May 27, 2015 10:04 am
just an additional note:
If your server is not in UTC you need to specify the following in your config/config.php:
Code: Select all
'logtimezone' => 'Europe/Berlin',
(Replace Europe/Berlin with the matching one of your system)
Without this fail2ban won't detect failed logins as there is a time difference (in my case UTC -> CEST = 2h) and won't ban failed logins.
*gone*
stefe
ownCloud version: 7.0.3
Webserver: Apache
OS: Linux Hosting Package
PHP version: 5.4
Postby stefe » Tue Jul 07, 2015 10:55 pm
I think for 8.1 thre is a new regex:
Code: Select all
{"reqId":".*","remoteAddr":".*","app":"core","message":"Login failed: '.*' \(Remote IP: '<HOST>\)","level":2,"time":".*"}
But why is in my logfile a " ' " missing at the end of the ip adress?
