All Clients stuck in Sync cycle
edalee
ownCloud version: 8.2.2
Webserver: nginx
PHP version: 5.6.6
Postby edalee » Sat Apr 11, 2015 3:39 pm
Hi O.C'ers,
I've hit the wall!
And, can't find enough info in my logs to determine the problem.
ISSUE:
All my clients (Windows, OSX, Linux) seem to be stuck in purgatory.
They are all in "Discovery limbo" mode with the sync in a continuous cycle. When they sometimes can break out of the cycle and then re-download existing files. The Server has 153 GB of data on an external HD, and the clients report 33G used. The sync has stopped uploading 200GB of files remains to be uploaded.
Below, are highlight from my various log files and the import configuration information.
Any help would be really appreciated. And, thank you very much in advance for your time.
SYSTEM INFO:
Arch / Nginx 1.6.2 / UWSGI (socket) / PHP (5.6.6)
LOG NGINX:
Code: Select all
[warn] 7919#0: *5573 an upstream response is buffered to a temporary file /var/lib/nginx/uwsgi/7/03/0000000037 while reading upstream,
LOG UWSGI:
Code: Select all
Respawned uWSGI worker 3 (new pid: 14271)
[pid: 14203|app: -1|req: -1/6121] IP:*********** () {46 vars in 735 bytes} [Sat Apr 11 13:24:24 2015] PROPFIND /remote.php/webdav/ => generated 513 bytes in 1853 msecs (HTTP/1.1 207) 13 headers in 652 bytes (0 switches on core 0)
worker 4 killed successfully (pid: 14154)
uWSGI worker 4 cheaped.
[pid: 14271|app: -1|req: -1/6127] IP:*********** () {46 vars in 987 bytes} [Sat Apr 11 13:24:29 2015] PROPFIND  /remote.php/webdav/014--projects/george_project/support_assets/Booklet_Instructions => generated 427 4276 bytes in 1486 msecs (HTTP/1.1 207) 13 headers in 652 bytes (1 switches on core 0)
LOG OWNCLOUD:
Code: Select all
{"reqId":"22b9aa5914747d63b0a48c3f643e9290","remoteAddr":"IP:***********","app":"PHP","message":"Module 'zip' already loaded at Unknown#0","level":3,"time":"2015-04-11T11:29:16+00:00","method":"PROPFIND","url":"\/remote.php\/webdav\/006--programming\/001--Python_Dev\/flask\/temperature_convertor\/.git\/objects\/b2"}
NGINX CONF:
Code: Select all
user http;
worker_processes  1;
error_log  logs/error.log;
#error_log  logs/error.log  notice;
#error_log  logs/error.log  info;
# pid        logs/nginx.pid;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    server_names_hash_bucket_size  128;
    # log_format main '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    # access_log  logs/access.log  main;
    # tcp_nopush     on;
    sendfile        on;
    keepalive_timeout  65;
    #gzip  on;
    ##    Virtual Host Configs    ##
    # include /etc/nginx/conf.d/*.conf;
    include /etc/nginx/sites-enabled/*;
SITE CONF:
Code: Select all
server {
  listen 443;
  server_name xyz.com;
  ssl on;
  ssl_certificate certs/conf/ssl-xyz-unified.crt;
  ssl_certificate_key certs/conf/pk-ssl-decry.key;
  ssl_session_timeout  5m;
  ssl_protocols SSLv3 TLSv1;
  ssl_ciphers HIGH:!aNULL:!MD5;
  ssl_prefer_server_ciphers on;
  root  /usr/share/webapps/owncloud;
  client_max_body_size 2G;
  rewrite ^/caldav(.*)$ /remote.php/caldav$1 redirect;
  rewrite ^/carddav(.*)$ /remote.php/carddav$1 redirect;
  rewrite ^/webdav(.*)$ /remote.php/webdav$1 redirect;
  error_log /srv/http/xyz.com/logs/error.log notice;
  access_log /srv/http/xyz.com/logs/access.log;
  location ~ ^/(?:\.htaccess|data|config|db_structure\.xml|README) {
      deny all;
  location ~ ^(.+\.php)(.*)$ {
    include uwsgi_params;
    uwsgi_modifier1 14;
    uwsgi_pass unix:///run/uwsgi/owncloud.sock;
    #uwsgi_pass 127.0.0.1:3001;
  location / {
    index index.php;
    # The following 2 rules are only needed with webfinger
    #rewrite ^/.well-known/host-meta /public.php?service=host-meta  last;
    #rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
    rewrite ^/.well-known/carddav /remote.php/carddav/ redirect;
    rewrite ^/.well-known/caldav /remote.php/caldav/ redirect;
Uwsgi Socket CONF:
Code: Select all
[uwsgi]
master = true
#socket = 127.0.0.1:3001
socket = unix:/run/uwsgi/owncloud.sock
uid =  http
gid = http
chmod-socket = 775
logto = /srv/http/xyz.com/logs/uwsgi-errors.log
# Change this to where you want ownlcoud data to be stored (maybe /home/owncloud)
owncloud_data_dir = /usr/share/webapps/owncloud/data/data
chdir             = %(owncloud_data_dir)
plugins = php
php-docroot     = /usr/share/webapps/owncloud
php-index       = index.php
# only allow these php files, I don't want to inadvertently run something else
php-allowed-ext = /index.php
php-allowed-ext = /public.php
php-allowed-ext = /remote.php
php-allowed-ext = /cron.php
php-allowed-ext = /status.php
php-allowed-ext = /settings/apps.php
php-allowed-ext = /core/ajax/update.php
php-allowed-ext = /core/ajax/share.php
php-allowed-ext = /core/ajax/requesttoken.php
php-allowed-ext = /core/ajax/translations.php
php-allowed-ext = /search/ajax/search.php
php-allowed-ext = /search/templates/part.results.php
php-allowed-ext = /settings/admin.php
php-allowed-ext = /settings/users.php
php-allowed-ext = /settings/personal.php
php-allowed-ext = /settings/help.php
php-allowed-ext = /settings/ajax/getlog.php
php-allowed-ext = /settings/ajax/setlanguage.php
php-allowed-ext = /settings/ajax/setquota.php
php-allowed-ext = /settings/ajax/userlist.php
php-allowed-ext = /settings/ajax/createuser.php
php-allowed-ext = /settings/ajax/removeuser.php
php-allowed-ext = /settings/ajax/enableapp.php
php-allowed-ext = /core/ajax/appconfig.php
php-allowed-ext = /settings/ajax/setloglevel.php
php-allowed-ext = /ocs/v1.php
#default language
intl.default_locale = en_US.UTF-8
# set php configuration for this instance of php, no need to edit global php.ini
php-set = date.timezone=Etc/UTC
php-set = open_basedir=%(owncloud_data_dir):/tmp/:/usr/share/pear/:/usr/share/webapps/owncloud:/etc/webapps/owncloud:/usr/share/webapps/owncloud/data/data:/usr/share/webapps/owncloud/config/config.php:
php-set = post_max_size=2024M
php-set = upload_max_filesize=2024M
php-set = always_populate_raw_post_data=-1
# load all extensions only in this instance of php, no need to edit global php.ini
php-set = extension=bz2.so
php-set = extension=curl.so
php-set = extension=intl.so
php-set = extension=openssl.so
php-set = extension=pdo_sqlite.so
php-set = extension=exif.so
php-set = extension=gd.so
php-set = extension=imagick.so
php-set = extension=gmp.so
php-set = extension=iconv.so
php-set = extension=mcrypt.so
php-set = extension=sockets.so
#php-set = extension=sqlite3.so
php-set = extension=xmlrpc.so
php-set = extension=xsl.so
php-set = extension=zip.so
processes = 10
cheaper = 2
cron = -3 -1 -1 -1 -1 /usr/bin/php -f /usr/share/webapps/owncloud/cron.php 1>/dev/null
OWNCLOUD CONF.PHP:
Code: Select all
<?php
$CONFIG = array (
  'instanceid' => '***********',
  'passwordsalt' => '**********************',
  'trusted_domains' =>
  array (
    0 => 'xyz.com',
    1 => 'xyz.com',
  'datadirectory' => '/usr/share/webapps/owncloud/data/data',
  'overwrite.cli.url' => 'https://xyz.com',
  'dbtype' => 'mysql',
  'version' => '8.0.2.0',
  'dbname' => 'owncloud',
  'dbhost' => 'localhost',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'oc_********',
  'dbpassword' => '************',
  'installed' => true,
  'mail_smtpmode' => 'smtp',
  'mail_from_address' => '***********',
  'mail_domain' => '**********',
  'mail_smtphost' => '**************',
  'mail_smtpport' => '587',
  'mail_smtpauth' => 1,
  'mail_smtpname' => '****************',
  'mail_smtppassword' => '************',
  'loglevel' => 0,
  'theme' => '',
  'maintenance' => false,
  'secret' => '********************',
  'forcessl' => true,
  'forceSSLforSubdomains' => true,
That's the lot!
Any help will be great!
Ed
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Re: All Clients stuck in Sync cycle
Postby tflidd » Mon Apr 13, 2015 11:54 am
Did you try to sync a smaller amount of data? It could reveal configuration problems with your webserver/php/database. I don't know UWSGI, are you sure not to run into process limits?
On the client side, it would be interesting to have the client log at the moment the client starts to download again files. Did you run all clients at the same time? Is it the same user?
edalee
Webserver: nginx
PHP version: 5.6.6
Postby edalee » Thu Apr 16, 2015 11:12 pm
Hi tflidd,
Thanks for answering... The configuration of the UWSGI socket is the one recommended on the Arch website.
I upgraded the Raspberry Pi B+ to a Raspberry Pi-2 B+, which was running the same set-up.
Raspberry Pi-2 digested the migration with only the OC-8 upgrade issue.
Ran fine for over 10 days, and then got into this sync issue.
It is across two users, on separate IPs, on different OSes, both experiencing the same issue. Both sharing a shared folder and group.
Whilst trying to debug the issue, I did read of a similar occurrence on O.C's Git repo where the:
Code: Select all
[warn] *5573 up-streaam response
occurred with Nginx. So this is the only lead I have for now...
Here is a section from one of the client logs:
Code: Select all
04-16 19:49:54:101 0x7fb31cd16a38 OCC::DiscoveryJob::remote_vio_opendir_hook: static csync_vio_handle_t *OCC::DiscoveryJob::remote_vio_opendir_hook(const char *, void *) OCC::DiscoveryJob(0x7fb31cd27c30) 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources ...Returned from main thread
04-16 19:49:54:101 0x7fb31cd16a38 csync_walker: directory: *************s://*************/remote.php/webdav/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn [file_id=00044840547645208f1c3]
04-16 19:49:54:102 0x7fb31cd16a38 _csync_detect_update: file: 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn, instruction: INSTRUCTION_NEW <<=
04-16 19:49:54:102 0x7fb31cd16a38 csync_ftw: URI without fuzz for *************s://*************/remote.php/webdav/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn is "007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn"
04-16 19:49:54:102 0x7fb31cd16a38 OCC::DiscoveryJob::remote_vio_opendir_hook: static csync_vio_handle_t *OCC::DiscoveryJob::remote_vio_opendir_hook(const char *, void *) OCC::DiscoveryJob(0x7fb31cd27c30) 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn Calling into main thread...
04-16 19:49:54:136 0x7fb319d0daf0 OCC::AbstractNetworkJob::start: !!! OCC::LsColJob created for  QUrl( "https://*************" )  querying "/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn"
04-16 19:49:55:552 0x7fb319d0daf0 OCC::DiscoveryMainThread::singleDirectoryJobResultSlot: void OCC::DiscoveryMainThread::singleDirectoryJobResultSlot(QLinkedList<csync_vio_file_stat_t *>) Have 6 results for  "/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn"
04-16 19:49:55:554 0x7fb31cd16a38 OCC::DiscoveryJob::remote_vio_opendir_hook: static csync_vio_handle_t *OCC::DiscoveryJob::remote_vio_opendir_hook(const char *, void *) OCC::DiscoveryJob(0x7fb31cd27c30) 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn ...Returned from main thread
04-16 19:49:55:554 0x7fb31cd16a38 csync_walker: file: *************s://*************/remote.php/webdav/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/all-wcprops [file_id=00044848547645208f1c3 size=443]
04-16 19:49:55:555 0x7fb31cd16a38 _csync_detect_update: file: 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/all-wcprops, instruction: INSTRUCTION_NEW <<=
04-16 19:49:55:555 0x7fb31cd16a38 csync_walker: file: *************s://*************/remote.php/webdav/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/entries [file_id=00044844547645208f1c3 size=609]
04-16 19:49:55:556 0x7fb31cd16a38 _csync_detect_update: file: 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/entries, instruction: INSTRUCTION_NEW <<=
04-16 19:49:55:556 0x7fb31cd16a38 csync_walker: directory: *************s://*************/remote.php/webdav/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base [file_id=00044847547645208f1c3]
04-16 19:49:55:557 0x7fb31cd16a38 _csync_detect_update: file: 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base, instruction: INSTRUCTION_NEW <<=
04-16 19:49:55:557 0x7fb31cd16a38 csync_ftw: URI without fuzz for *************s://*************/remote.php/webdav/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base is "007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base"
04-16 19:49:55:557 0x7fb31cd16a38 OCC::DiscoveryJob::remote_vio_opendir_hook: static csync_vio_handle_t *OCC::DiscoveryJob::remote_vio_opendir_hook(const char *, void *) OCC::DiscoveryJob(0x7fb31cd27c30) 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base Calling into main thread...
04-16 19:49:55:601 0x7fb319d0daf0 OCC::AbstractNetworkJob::start: !!! OCC::LsColJob created for  QUrl( "https://*************" )  querying "/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base"
04-16 19:49:56:997 0x7fb319d0daf0 OCC::DiscoveryMainThread::singleDirectoryJobResultSlot: void OCC::DiscoveryMainThread::singleDirectoryJobResultSlot(QLinkedList<csync_vio_file_stat_t *>) Have 0 results for  "/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base"
04-16 19:49:56:999 0x7fb31cd16a38 OCC::DiscoveryJob::remote_vio_opendir_hook: static csync_vio_handle_t *OCC::DiscoveryJob::remote_vio_opendir_hook(const char *, void *) OCC::DiscoveryJob(0x7fb31cd27c30) 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base ...Returned from main thread
04-16 19:49:56:999 0x7fb31cd16a38 OCC::DiscoveryJob::remote_vio_closedir_hook: static void OCC::DiscoveryJob::remote_vio_closedir_hook(csync_vio_handle_t *, void *) OCC::DiscoveryJob(0x7fb31cd27c30) "/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base"
04-16 19:49:56:999 0x7fb31cd16a38 csync_ftw:  <= Closing walk for *************s://*************/remote.php/webdav/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/prop-base with read_from_db 0
04-16 19:49:56:999 0x7fb31cd16a38 csync_walker: directory: *************s://*************/remote.php/webdav/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/props [file_id=00044849547645208f1c3]
04-16 19:49:57:000 0x7fb31cd16a38 _csync_detect_update: file: 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/props, instruction: INSTRUCTION_NEW <<=
04-16 19:49:57:000 0x7fb31cd16a38 csync_ftw: URI without fuzz for *************s://*************/remote.php/webdav/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/props is "007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/props"
04-16 19:49:57:000 0x7fb31cd16a38 OCC::DiscoveryJob::remote_vio_opendir_hook: static csync_vio_handle_t *OCC::DiscoveryJob::remote_vio_opendir_hook(const char *, void *) OCC::DiscoveryJob(0x7fb31cd27c30) 007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/props Calling into main thread...
04-16 19:49:57:044 0x7fb319d0daf0 OCC::AbstractNetworkJob::start: !!! OCC::LsColJob created for  QUrl( "https://*************" )  querying "/007--Resources/Trapcode.12.Full.For.Mac.OSX/Trapcode Suite 12.0.0/TCSuite_Mac_Full/Guru Presets/DVinson_SuperRays_1.0.1.mpkg/Contents/Plugins/Registration.bundle/Contents/Resources/.svn/props"
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Apr 17, 2015 6:17 am
have you considered to use a config without uwsgi which is known to work (see OC docs)?
*gone*
edalee
Webserver: nginx
PHP version: 5.6.6
Postby edalee » Mon Apr 20, 2015 11:32 pm
Thanks for the suggestion Real Rancor.
I did consider this set-up and I even had it running at one stage, early on. The relative performance gained from running them in unity is a huge benefit on a small form computer, like the Raspberry Pi; that is why Arch recommends this as the preferred method.
Although, taking a potential break-point out of the chain is a good idea. It does go against my instincts; as this also occurred after upgrading the O.C clients and upgrading the O.C itself, after a migration to a new machine.
I will therefore, log the possible issue via Github and/or via email with O.C development team. Then rebuild; delete all the clients local data and re-sync all the data to a new O.C set-up and new database. A clean start if you will. Then see if the issue occurs again.
